Rear A-arm Ball Joint - Defender Source
Old February 24th, 2004, 10:41 AM
ronward's Avatar
ronward
Redsrover
None - sadly
Can this thing seize up and cause the truck to lean to one side or the other? I installed OME 751/762's on my truck last summer and ever since there's been a 1/2" lean to the drivers side. I've shimmed and tweaked to get it level ever since.
I bought two of EE's spring isolators and put them both on the same rear drivers side spring (one top, one bottom) with a 10mm OME spring packer on top of that. That's pretty close to 3/4" of an inch all total. I measured the passenger side rear spring before I changed anything and it was 14 3/4" while the driver side was 14" even. After the installation of the spring isolators and the spring packer the driver side rear spring measured just over 15". I stood on the rear bumper and jumped up and down to settle things and then measured from pavement to fender arch and dang if the passenger side wasn't a bit higher than before, AND still a good 1/4" taller than the driver side. The driver side did increase in height by the 3/4" I added in.
It looks fine, but I am puzzled to no end by this. I have removed the rear sway bar and all else is stock. The ball joint in the rear looks fine and I have good articulation off road and no weird clunks or sounds. Truck is a 1997 soft top with 23000 miles, 255/85 BFG MTs.
Any one have ideas?
Ron
Old February 24th, 2004, 11:22 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ron, it would not be the ball joint. Prob. just a bad spring or maybe the wrong spring.
Legend in My Own Mind.
Old February 24th, 2004, 12:04 PM
ronward's Avatar
ronward
Redsrover
None - sadly
Well, with my luck they will all start to sag within a few days of their one year birthday and I'll have to replace them with something anyway...
Old February 25th, 2004, 03:46 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
It sounds like you got one spring of the incorrect spec.
Old February 25th, 2004, 08:53 AM
ronward's Avatar
ronward
Redsrover
None - sadly
That's what I thought Wicks. But just last night I rolled up under there and checked the OME tags on each spring and they are all correct, assuming someone at the factory didn't put the wrong tag on one of the springs... I should probably put in a call to John at EE, but I have it level now (sort of). I'd like to go to the rear heavy duty springs at some point anyway...
Ron
steering drop arm ball joint souza Defender Technical Discussions 20 February 29th, 2008 11:41 AM
ball joint on the rear link/a arm rover4x4 Defender Technical Discussions 11 September 30th, 2007 08:09 PM
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
