Really Tippy off road - Defender Source
Old August 21st, 2014, 04:17 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
OK. I'm getting frustrated with trying to figure out why my D90 SW is sooo tippy off road. I've seen other Defenders with bigger tires, taller lifts and heavier loads on them driving sideways with no issue. I have 95 hardtop, 33 inch tires, RTE 2 inch springs, safety devices roof rack(which I only load with pillows or sleeping bags), Bilstien 7100s valved 360/80. From what I can tell via searches, it's fairly common setup so i don't know why my truck is being so weird. It's down right terrifying to drive, primarily it "swings" around going over bumps. It does not have sway bars but I've tried putting the front back on and I didn't notice much of an improvement. since the truck drives off road like it's on pogo sticks my only guess is shock valving. I've thus switched to Fox 2.0 shocks to see if what will help. On road, no issues. drives relatively stiff actually. Makes me think the shock has plenty of high speed dampening but absolutely zero low speed dampening.
That said, I'm about out of ideas. Could it be a geometry issue in the suspension or something else I'm not considering?
Old August 21st, 2014, 04:29 PM
Video?
Have you driven it without the rack on?
Have you driven other D90s?
Old August 21st, 2014, 04:42 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Supposedly correct valving for a d90 in 7100s is 400/100 but I don't know if that will make that much difference...
The front end has a lot of anti-sway built in because of the four link geometry... The rear is where all the flex is....
Do you have your springs retained? Makes a huge difference....
Did you look for bushing wear... Rear links and a arm?
Old August 21st, 2014, 04:55 PM
You wouldn't have a 3-link would you? I have soft springs and shocks, no sway bars and it is not tippy at all.
Old August 21st, 2014, 05:11 PM
one thing to consider: shocks can't do anything if you have no droop.
Old August 21st, 2014, 05:21 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Most of these trucks are setup with a lot of droop and little compression... But good point...
Old August 21st, 2014, 05:23 PM
transientmechanic's Avatar
transientmechanic
1972 SIII
Sounds like all the bushings in your rear suspension are shot and the ball joint is worn out.
Old August 21st, 2014, 06:05 PM
the rover shop
shayne young
You live in New York and take your 90 off road???..WTF.... I heard all you New York guys were just poseurs and only talk about how you would do it and show pics of how other people offroad..wouldn't wanna get those boosts dirty..!!!!....
Old August 21st, 2014, 06:27 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Sounds a bit much for 33in tires?
also, are the shocks charged up?
Old August 21st, 2014, 06:30 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Car does not have a 3 link. Parked right next to mine is my brothers 94 D-90 ST. Granted, lighter up top and it's bone stock but it's like day and night on the trail. My Springs are not retained but why would that matter longest the springs weren't dislocating? Never drove it with the rack off but I feel it's been getting worse and worse.
The ball joint on the rear A arm is original. The boot is all torn up and probably needs to be fixed but why would that joint matter for stability?
I moved to San Francisco.. now the Rubicon is my closest trail and I can make Moab in a day. Jealous?
Old August 21st, 2014, 07:08 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Originally Posted by sflash868 View Post
Car does not have a 3 link. Parked right next to mine is my brothers 94 D-90 ST. Granted, lighter up top and it's bone stock but it's like day and night on the trail. My Springs are not retained but why would that matter longest the springs weren't dislocating? Never drove it with the rack off but I feel it's been getting worse and worse. The ball joint on the rear A arm is original. The boot is all torn up and probably needs to be fixed but why would that joint matter for stability? I moved to San Francisco.. now the Rubicon is my closest trail and I can make Moab in a day. Jealous?
If a arm ball is worn there will be more play in the rear as the trailing arms are then locating the rear axle....
Unretained springs give more of a tippy feeling as the rear end is less predictable... Retained springs also force the front end to articulate more... But it sounds like you are having issues during less extreme terrain.
2" of lift with 33s is fine... Ran that way for a while and was a good setup... Wouldn't have changed it if I hadn't wanted a taller tire...
Old August 21st, 2014, 07:11 PM
Check the radius arm bushings at the axle.
Old August 21st, 2014, 07:16 PM
transientmechanic
1972 SIII
Dude fix the obvious problems with the suspension first (thrashed 20 year old rear ball joint) to baseline it then go from there. Have any of the other suspension bushings been replaced or are they original too?
A bad ball joint will cause the "loose" rear end feeling you are describing. "Terrifying to drive, swings around over bumps"
Old August 21st, 2014, 09:21 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Have you put it on its side? Maybe it just feels tipsy.
Old August 21st, 2014, 09:37 PM
Roll it over and report back.
Old August 21st, 2014, 09:48 PM
87 D110 (Ruby)
ummmm - why don't you check first and see if you have anti sway bars...seems to me at least that he may not have them
Old August 22nd, 2014, 12:36 AM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
Watch it pal.
Old August 22nd, 2014, 10:11 AM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
This explains your Rubicon post from a couple of months ago. I was thinking that's a long haul from New York.
Old August 22nd, 2014, 10:29 AM
crown14's Avatar
crown14
Verticalscrote
I'm betting the Bilsteins need a charge
Old August 22nd, 2014, 10:55 AM
the rover shop
shayne young
That's definitely the most likely.. Without the shocks to dampen its side to side movement the body builds up momentum quickly and that momentum carries on uninterrupted until the spring pressure can overcome it and start tipping it back..
off road
Land Rover Defender Survives 22,000 Mile Really, Really Cold Trip waveridin1959 Misc. Chit-Chat 7 March 6th, 2014 09:35 PM
Really? Plastic Defender parts? Really? Roving Beetle Misc. Chit-Chat 12 October 6th, 2010 09:02 PM
Tippy lifted Truck Rugbier Defender Technical Discussions 26 May 22nd, 2009 02:10 PM
Really really basic question..... CaptMidnite Defender Technical Discussions 1 January 5th, 2007 10:24 AM
Worst day off-road.. (really long, i'm bored) sflash868 Misc. Chit-Chat 24 October 23rd, 2006 01:42 AM
