ready to buy JW Speaker headlights have questions - Defender Source
Old February 26th, 2014, 11:52 AM
defender1844
Amit Likhyani
There is a set for $750 on ebay for Jeeps that include some kind of conversion harness from H4. Can I just throw away the conversion harness for a jeep and plug the H4 connector in directly?
The next question: do I need to install a relay or are they low power enough to just wire into the existing harness with no mods?
Old February 26th, 2014, 12:02 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
I would think the conversion harness just adapts from the H4 plug on the housing to whatever the Jeep uses, so you can probably toss it.
They definitely draw less than the stock headlamps, so you don't necessarily need a relay. The last set I ran just plugged directly into the stock harness on the truck and were good to go. There's a measurable drop in voltage when running directly off the switch, but for an LED application I don't know that you will see an increase in output if you were to power them off a relay.
-Ash
Geared Restoration Co.
352-572-3236
Old February 26th, 2014, 12:19 PM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
If you call Discount Fleet Supply, they will discount the JW Speaker 8700. I called last week for a price and they said they could do $700 for the pair. Just a thought.
Old February 26th, 2014, 01:00 PM
defender1844
Amit Likhyani
thanks a ton Roverenvy
Old February 26th, 2014, 06:58 PM
Roverenvy's Avatar
Roverenvy
Michael
1994 Defender 90
No problem, glad to help. I'm about to buy a set of LED headlights myself. I agree that the JW Speak look nicer from an outward appearance. And from the research I've done, the JW Speaker is better on low beam BUT the Trucklite Phase 7 is better on high beams. The Trucklite is $355 for a set. (That price is the best they can do.) I'm going with Trucklite, try as I might I just can't justify spending the difference.
Old February 26th, 2014, 08:14 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
Group buy? Truck lights ?
Defender 110
Old February 26th, 2014, 08:56 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Group buy!
Old February 26th, 2014, 09:06 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Gents, use DiscountFleetSupply.com $354.99, free shipping, minus 5% discount using code (hdled5 I think) for a total of $337.24 a set.
ht, lights
Low Beam Headlights Quit JimC Defender Technical Discussions 7 January 29th, 2006 07:54 PM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
Yaaaaaaaaaaaarg! Frigging headlights solihul Defender Technical Discussions 2 June 23rd, 2005 10:29 PM
Replacement Speaker w/ stock grille??? swm9476 Misc. Chit-Chat 0 April 1st, 2005 09:55 AM
Expedition Ready Range Rover RedRhinoProducts For Sale - Vehicles 0 September 19th, 2004 01:12 PM
