Read door rebuild hinge kit Image needed - Defender Source
Old November 7th, 2006, 10:59 AM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Hello. I know this has been addressed before, but i need an image of how the rebuild kit for the rear door hinges goes together. so far i have the long bolt, spring, gold ball thing and end nut. how do these all go together?
thanks!
Old November 7th, 2006, 11:44 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Ball goes between the 2 hinge pieces
Then bolt goes through hinges and ball
Spring goes up the bottom, then lock plate and finally nut.
The new style elimiates the lock plate that you bend over in favor of a cap nut and some loc-tite on the bolt.
Email:
Old November 7th, 2006, 12:01 PM
ini88's Avatar
ini88
Daniel Marcello
Thanks ERC!
Question: if the ball goes inbetween the two hinge pieces, will I need to place the hinge that connects to the frame higher, and the one that connects to the door lower? because right now both of the hinge piece line up together. will the 1/2 inch tall ball piece off set the hinges to much?
Old November 7th, 2006, 01:12 PM
ECR's Avatar
ECR
Don't know exactly what you mean... when we do it and it is more than just a stright replacement we leave all the hinges loose on the body parts, then make the door or tailgate fit and adjust as needed, then tighten everything down after the body gaps and all look right.
Email:
door, kit, rebuild
TD5 Door Hinge Kit NTO in ROW Green 150.00 shipped SafariHP The Vendors Loft 0 October 10th, 2009 08:33 AM
NTO TD5 Front Door Hinge Kit SafariHP The Vendors Loft 20 February 19th, 2009 07:22 AM
Defender / Series Door Hinge Kit / TD 5 Bonnet Cable SafariHP For Sale - Parts 1 August 25th, 2007 09:58 PM
Door Sill (Carpet) Trim - D90 Wagon Kimos Defender Technical Discussions 14 October 28th, 2004 08:55 PM
Door seal and gutter kit Chris Cox Defender Technical Discussions 11 March 7th, 2004 10:52 PM
