Re-wiring a 110 ... - Defender Source
Old August 10th, 2006, 06:54 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Re-wiring a 110 ...
When they did the chassi swap in the UK they took the lazy way and chopped all the electric at the bulkhead and then kind of put them back in some sort of order. And since the body is from a Td5 truck and is now fitted with a 200 tdi well ther is just a whole bunch of cut wires and it is not clean at all.
So now I need to re-wire the 110, anyone know the best route to go about ... new wiring harness (wich one) ? or home made one like OEM same color code and all (the route I previously used).
Thanks for all your "savoir faire" !
Pat
Kirk Lazarus, Tropic Thunder
Old August 10th, 2006, 09:22 PM
JSQ's Avatar
JSQ
Jack Quinlan
I rewired my 110 pretty quickly after I got it. The original loom was burned up in places and had been tapped into and spliced in so many places by various generations of Canadian soldiers that I decided to hell with it.
I secured a firewall engine harness for a civie car but I had to create my own harness for the lighting. I had the advantage of working with a 2.5 NA diesel and a softop so my electrics were at a minimum, but a 200tdi should still be pretty simple.
I really recommend trying to obtain the firewall harness. I can't imagine making this from scratch. Doing the lights and what not aren't a big deal, but mainly because there's plenty of room to run it all. The other nice thing about using the factory harness is that the stripey current carrying (not BUS) wire you see on your truck is very hard to come by. Essentially, striped wire is expensive and difficult to find which means that if you weave your own loom it won't match up to the factory wiring diagram. It's nice for those wires to be the proper colors later on when you're trying to trouble shoot a problem.
It was a fair amount of work for me, maybe 20 to 30 hours for the whole job, but in the end I felt great knowing everything worked properly and would be reliable. Plus if you haven't done it before you'll learn quite a bit.
Old August 10th, 2006, 10:08 PM
Retrofit's Avatar
Retrofit
Pat
I have rewiered a couple of cars before and a "Heep" too but I was just wandering if it is hard to get the OEM harness or something similar but from what I have read i will probably make my own from scratch with the proper color coding and so on ... Unless someone points me in an other direction ...
Pat
Any take on the Painless wiring harness ?
www.painlesswiring.com
Old August 10th, 2006, 10:20 PM
I used a painless subharness for my accessories and located one of their weatherproof fuseboxes in the battery box under the seat. Its high quality.
I re-wired my truck when it was apart with a new main body harness from Rovers Down South. It was around 600 buck a couple years ago, but I prefer to have a stock set up.
Old August 11th, 2006, 04:15 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
I built my harness, all wiring colour codes match, all wiring contained in convoluted tubing. Just takes a lot of time beforehand figuring out all the colours you need and amounts, how many multiplugs you need, which ones etc. Rigging it all up wasn't too bad. I had more bother because I was installing my own custom fure/relay board and rewiring the dash completely as well
ID:	6208   Click image for larger version
Old August 11th, 2006, 03:02 PM
JSQ's Avatar
JSQ
Jack Quinlan
That looks pretty clean.
your truck has about 12 more relays than mine.
lol.
Old August 14th, 2006, 04:04 AM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
it doeas, thats one of the advantages of building your own harness, you can incorporate everything that you need at the start. The additional relays are for roof mounted spotlights, air horns and the twin electic fans
110, wiring
early 110 dash wiring Abrooks Defender Technical Discussions 7 May 28th, 2008 04:34 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
