Re-trimming Old Style Seats (Hard Back) - Defender Source
Old August 10th, 2016, 09:37 PM
DreamRover's Avatar
DreamRover
AJ
ROW 1984 D90
Has anyone had success in using an exmoor seat re trim kit on old style seats with a hard plastic back? Any crazy ideas welcome.
Old August 11th, 2016, 05:35 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The back foam is different as is the frame. The seat base is the same. I tried to do one but found it really didn't work. However have heard of somebody doing it with minor modifications.
Land Rover 110
Old August 11th, 2016, 06:08 AM
sjpin
Scott P
I did it about 18 months ago and I had to trim the foam. I went slowly and did a little at a time on the first one and the second one was much easier. I knew about the issue going into it from this thread: http://www.defendersource.com/forum/...ats-49761.html
The thread talks about having issues zipping the cover closed once you get it on the seat, but mine wasn't do bad and I did get it zipped all the way. Again the first seat took a little longer than the first. I hated the idea of trimming out the foam when I was doing it, but it has worked out fine. The seats look fine and are comfortable.
Old August 11th, 2016, 06:25 AM
Have done it. You must order the covering kit special from Rovers North. Julian/Exmoor has the patterns for every Land Rover seat ever made. Talk to Arthur up there at RN. They do not have new back foams so if you can save those, you are golden. However, i will say that having been through the ordeal that it is actually far less hassle to simply order new seats. There is a real possibility of damaging the material as you are installing it, and then you will have to wait possibly weeks for a replacement part to come from the UK. All you are going to be saving from the old seats is the frame, and that, once you get down to it, is of little value especially if it is rusty or needs to be cleaned up or refinished. The tray backs are actually not as nice as the next-gen seats.
While you are at it, order them with the seat heaters installed.
ac, seats
Old style front seats budzny For Sale - Parts 11 July 13th, 2016 08:57 AM
TF001 How much trimming for terrafirma winch bumper speedpin Defender Technical Discussions 0 June 14th, 2015 09:40 AM
trimming fuel tank mattarm Defender Technical Discussions 2 August 3rd, 2014 03:07 PM
Fender Flare trimming? BradforD90 Misc. Chit-Chat 6 March 2nd, 2009 11:16 AM
Preferred tool for flare trimming? KevinNY Defender Technical Discussions 6 February 26th, 2007 08:33 PM
