Re-trim early d90 seats - Defender Source
Old November 19th, 2013, 07:53 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
Has anyone recovered an early ~'85, hardback seat w/ the current re-trim kits? I am getting conflicting info from various vendors. Thank you.
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old November 19th, 2013, 08:27 AM
w
yes. I did a couple of sets of 1983 seats with exmoor's black leather kits. someone is giving you bad info
Old November 19th, 2013, 08:32 AM
usadventureracing's Avatar
usadventureracing
Brett
110
Yes, I have also.
1983 ROW D110
1970 Series III (Parting out)
Old November 19th, 2013, 09:04 AM
Abrooks's Avatar
Abrooks
Tony Brooks
I did a set using the Britpart kit and it worked well. The only small issue is that the side bolster section of the frame is slightly wider in the early seats than the later ones and you'll need to finesse the new foam onto the frame.
Old November 19th, 2013, 09:26 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
thanks for the feedback and the tip.
w
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old December 28th, 2014, 09:09 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
Success....almost
Well, finally got around to the retrim, seats look great in Techno and without the cracked hardbacks. Fitting the seatback foam was a bit fiddly and required some trimming due to these being early seats.
Now the question: How the hell does the Exmoor zip-lock strip work closing the setback bottom? No matter how much I try, can't seem to get the two sides to engage.... Looks like it shoul be a simple engagement. Any hints or tricks before I throw a tantrum and dig out the hog rings? Thanks.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old December 28th, 2014, 09:17 PM
Green Blood's Avatar
Green Blood
Carl Phillips
1988 90- Swiss LHD 2.5 Petrol
If the kit is like the one for my '88 with the rubber fixing strip around the bottom edge, then the Exmoor video should help you:
I followed this to the tee and the job went well, albeit a bit fiddly.
Proud restorer and former owner of '94 NAS D90 #590- back in the hands of its original owners.
And now happy owner of a 1988 Swiss-Market D90 Station Wagon.
Old December 28th, 2014, 10:56 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
Thanks.....I had watched those tutorials in prepping. They just seem to press the two sides together and they click.... I'll bring the other seat to this point then attack the seat backs again. My seat back covers are a bit tighter than in the video, I am guessing that's due to mine being the early type and these kits are universal or for the later type.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old December 29th, 2014, 05:09 AM
I don't know how you are making the new covers fit the tray backs. They are quite different
Old December 29th, 2014, 10:37 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
Yes they are significantly different as are the shapes of the seat back foams...but the seats came out pretty well, very well actually considering the differences. So, it can be done, but requires some fiddling and trimming of the seat foams. If anyone plans on doing this I will put up a more detailed post; where to trim the foam, etc.
I had the same concern but after the feedback here and from a few others, most saying fiddly but doable, I attempted it and it came out well except for the final step. The final step is more of me not being able to zip the two sides together...
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old December 29th, 2014, 10:48 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
Pic of the results. Exmoor does make a very nice kit, if this was a later seat, this would have been a 2 hr job (excluding refinishing the seat frames)....and the only other time I've ever reupholstered seats was in 1991!
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old December 29th, 2014, 12:27 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Please share your experience. I have new retrim kits but cannot get it to fit the older hardback seat frames.
MUDSUX
Old December 29th, 2014, 11:15 PM
Green Blood
Carl Phillips
Looks great! Glad you got it sorted.
Old December 30th, 2014, 11:03 AM
pitchrollyaw
wayne p
1985 d90 2.5NA
thanks Green... Mudsux, I took some pics as I was doing it so I will post them and some details in a few days or so.
The fit is too tight to use the stock zip lock finisher so the early frames may be just a bit taller. I resorted to several black zip ties effectively lacing the two pieces together. I am not thrilled, bit too much of a kluge for me especially as the rest came out so well, but you can't see them on a 90 and they could easily be covered w/ a flap of material. If I was doing it over again, I would still would still go this route.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old December 30th, 2014, 06:04 PM
pitchrollyaw
wayne p
1985 d90 2.5NA
Here is what I did:
-Deepen the side bolster channels in the new seatback foam. This will allow the foam, especially the bolsters, to sit on the new seatbacks almost all the way back. You have to take out 1/2" or a bit more. In doing this you will be cutting through some of the woven reinforcement molded into the seatback. I reinforced the deeper grooves with Gorilla Tape, pressing it into the channels and overlapping the strips. This may be overkill as there is still a good amount of foam left after cutting.
-Taper the bottoms of the seatback foam side bolsters, this will allow the fabric face to pull under and around the bottom of the seatback, otherwise the outboard edges are very tight when you go to join the front and back together. Try to keep the original profile, just with less material.
-Taper the bottom edge of the seatback foam where it glues to the lower crossbar. Again, to enable the fabric to come under the seatback to join the backside of the cover.
-I removed the foam flap that folds over the headrest channel. It left a bulge and seemed to pull the headrest hole too far back (it will be stretched back a bit anyway).
The outer lip of the seatback foam will not be attached the seat frame all the way around..at least I could not get it to seat without more trimming then I wanted to do. The foam will seat on the top of the frame and maybe 1/3 of the way down, but the sides of the bolsters will angle forward a bit. Glue as much as you can, this will be unnoticeable with the covers on.
I'll add pics in the next post. I took these as I was working and the channel tape was not complete and the foam was only rough cut. Conservative trimming and many test fits are the way to go here. PM me if you have any questions.
------ Follow up post added December 30th, 2014 06:14 PM ------
Good luck.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old September 8th, 2015, 11:41 PM
9 months later, a reminder bump for install pics
Old September 9th, 2015, 06:29 AM
Just as an FYI, Julian has the patterns for these early seats. you have to contact Exmoor directly or thru RN. They do not make the foams any more for the backs, so you have to alter the new style,or like me, just stuff them into the cover.
90, d90, seats
Exmoor Trim USA new middle row 110 seats sneak peek ExmoorTrimUSA The Vendors Loft 32 November 18th, 2013 09:20 PM
D90 Jump Seats ddrotts For Sale - Parts 14 August 14th, 2009 02:48 PM
Jump Seats for D90/ Safety devices Rack icurnmedic Wanted 0 July 13th, 2006 06:57 PM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
