re-powder coating NAS 97 D 90 brush guard/ plastic winch cover - Defender Source
Old January 9th, 2016, 12:41 PM
havens51's Avatar
havens51
joseph
'97 NAS D90 ST, '88 D110, '16 LR 4
Can someone suggest how/who to handle the re- surfacing of my front brush guard? The original coating has lifted in a few places, especially the horizontal plates that connect it to the bumper. The truck is in MASS
Secondly, has anyone ever seen another D90 NAS with the factory WARN winch plastic cover still in place?
ID:	138908   Click image for larger version
Old January 9th, 2016, 12:44 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
sand blast and powder coat
good luck with your search
Old January 9th, 2016, 12:57 PM
bjf's Avatar
bjf
barry f
94 ST #395
The cover was an option. Bunch of people on here have them.
Old January 9th, 2016, 01:05 PM
havens51's Avatar
havens51
joseph
any recommendations for source in southern Mass?
Old January 9th, 2016, 01:06 PM
ron's Avatar
ron
Ron
Smile
or you can buy this one already done.. your in Orleans correct....
Old January 9th, 2016, 01:12 PM
As long as there are no holes in the BB, that's the way to go. Though you could also go with a rattle can or linex type finish.
Those Warn plastic covers are rare as hens teeth.
Old January 9th, 2016, 01:17 PM
I've got a cover in my basement, how is it supposed to be held on?
Old January 9th, 2016, 01:20 PM
havens51's Avatar
havens51
joseph
Thank you. I would like all the brush guard components to be in place. The truck is on Nantucket, and has been for the last 10 years or so.
------ Follow up post added January 9th, 2016 01:23 PM ------
The cover actually just snaps into place with a friction fit. The prior owner had a bungee cord holding it in place, but it lost elasticity and I have left it off. The bungee probably was not a bad idea.
Old January 9th, 2016, 03:11 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Factory powder coat on the bumpers is very difficult to sandblast off. I would recommend having it burnt off, and then sand-blasted. Many larger sandblasting companies have an oven to burn off coating, it's just more efficient.
If you go the extra mile and galvanize the bumper, and then powder coat, it would be the last time you ever need to do it. It won't ever rust, and if the coating is don properly, it won't ever blister either. (NAS factory rear bumpers were all galvanized before coating)
Old January 9th, 2016, 04:39 PM
havens51's Avatar
havens51
joseph
Great. Thank you for the timely and well considered info. I will see if I can't pull this off as you describe.
Old January 9th, 2016, 05:00 PM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by CDN38 View Post
Factory powder coat on the bumpers is very difficult to sandblast off. I would recommend having it burnt off, and then sand-blasted. Many larger sandblasting companies have an oven to burn off coating, it's just more efficient. If you go the extra mile and galvanize the bumper, and then powder coat, it would be the last time you ever need to do it. It won't ever rust, and if the coating is don properly, it won't ever blister either. (NAS factory rear bumpers were all galvanized before coating)
Nas bumpers were galvanized? You sure?
Old January 9th, 2016, 07:08 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Yes, the rears were so far as I know. Just had the coating burned off a 110 rear bumper, and had to bust off some of the grave to repair one of the tubes. You can weld galvanized steel, but the zinc can compromise the weld, and there are also issues with the gasses with the zinc plume. Need to cut away part of the tube on the right and replace it due to a nasty dent.
Old January 9th, 2016, 07:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
Anyone else know the answer to this? Mine didn't look like that after the coating was removed and I know people who had theirs dipped after burning the coating off.
Old January 9th, 2016, 08:48 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Mine is, but I'm not the original owner. Either way, the PC chipped in a couple places and I've just been doing touch up spray.
Scott, that bumper is coming along nicely. It doesn't look nearly as bad now in just Rover Chrome, but it made a mighty fine spoiler on my rack! ;-)
Old January 9th, 2016, 10:25 PM
bjf's Avatar
bjf
barry f
94 ST #395
Anyone else?
I can't see them galvanizing just bumpers.
Old January 9th, 2016, 11:13 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
...ok, so who has (or has seen) a rusted out rotten original NAS rear bumper? Anyone...?
Fronts peel and rust all the time, as well, the rear brake arches, and swing away carrier, but not the rear bumpers.
Old January 10th, 2016, 12:23 AM
bjf's Avatar
bjf
barry f
94 ST #395
I've seen a rusted one on the ecr site that was repaired.
I striped mine and it was not coated that I saw.
My nas 110 basket had what looked like galv on it when stripped but I don't think it was galvanized under the coating. Not sure what it was but had to have it chemicals stripped to get it clean.
Anyone want to chime in?
Old January 10th, 2016, 10:00 AM
bjf's Avatar
bjf
barry f
94 ST #395
Here is one pic I had laying around
90, 97, brush guard, cover, d 90, nas, winch
D110 External Cage Powder Coating... entering the rabbit hole? KMarshall Defender Technical Discussions 26 October 23rd, 2013 11:36 PM
Powder Coating a 110 Cage bjf Smaller Projects 8 July 3rd, 2009 06:44 PM
sand blasting and powder coating in colorado... TravelerBT Defender Technical Discussions 2 January 14th, 2009 06:32 PM
Alpine White Powder Coating? newfD90 Defender Technical Discussions 2 September 7th, 2007 12:26 PM
Powder Coating Stock Rims Weldon Defender Technical Discussions 6 June 29th, 2004 10:35 AM
