Re: Catalytic - Defender Source
Old June 4th, 2010, 07:48 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Re: Catalytic
My passenger side cat is bad, going to change it with magnaflow 94004, now since most likely may have to drop Y, do you recommend changing driver side as well? seems to make sense, change one, change both...... advise?
If so, can I use the same cat on driver side? right now they are different, passenger side is same shape as magnaflow and driver side is completely roun/ tubular. Any idea why would be different shape??
Thanks....
phil
Old June 4th, 2010, 07:57 AM
I would change them both at the same time, especially if they are original or you have high mileage. I have seen people use the same aftermarket cats on both sides, but check the fitment and if it will fit, do it.
Old June 4th, 2010, 08:07 AM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
I'm not sure if original..... they are Land Rover, but from Y back, its a fairly new Borla system..... mileage is high at 100K....
Old June 4th, 2010, 10:03 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I would change them both at the same time since the y will be out anyways. I used the same cat on both sides--it was the universal magnaflow as well--not sure which catalog number, but it certainly could have been that one...
Old June 4th, 2010, 10:31 AM
Thanks....
phil
Where are you getting this done? i tried meinke but they wouldn't do it ...
Old June 4th, 2010, 12:06 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
I called a mom & pop shop north of nyc and said they would do it...... they were cool on just bringing
cats in and they would install them..... you in city Jason?
Old June 4th, 2010, 12:31 PM
I am .. I have a spare Y-Pipe that needs some work ... maybe they could do that? Where are you?
Old June 4th, 2010, 01:23 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
I'm partially in city and upstate, shop is in East Fishkill area, about 1 hour north....
what do you need done? new cats as well? my exhaust is solid, like i said, Borla,
but cats may be original.... not sure, they are land rover make.
Old June 4th, 2010, 01:40 PM
I'm in beacon this weekend ... New cats and or mod my spare pipe.
I have a Borla SS cat back so looks like we have 2 of the same job!
Old June 4th, 2010, 06:32 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Ha... funny.... seems we share similar toys! This place is about 25-30 min from Beacon, let me know
if you want they're info or just hang back and see what they do with mine. The guy sounded good and
seemed willing to do what ever it took to get it done. Places like meineke are a corp machine, rarely
deviate from the usual.
I'm around this weekend and about 20 min from Beacon..... maybe hookup one of these days....
Old June 4th, 2010, 10:50 PM
I saw a 90 White SW with a galv roof rack parked up a few miles south of beacon tonight ... i'll PM you my cell
Share the details and lets see what they can do!
Old December 12th, 2011, 03:10 PM
Alright, so I just received my new Borla system over the weekend, replaced under warranty (muffler, pipe(s), tip). I haven't opened up the box yet, so I don't know if they sent a pamphlet on places to have this installed for free on their dime or not, but I'm also looking to do the catalytic converter / cats and o2 oxygen sensor (s) at the same time since I have some worn out cats, and threw a lambda code a few times over the past few months.
I'm looking to just cut the Y-pipe and have a shop just drop in and weld Magnaflow Universal 94004 cats in there. Is there any reason why I should replace the whole Y-pipe instead as seen here by part ESR3063?
http://www.roverparts.com/Parts/ESR3063.cfm
For just the Magnaflow 94004 there are a few different types on Amazon, depending on how they were originally shipped (P for pallet, D for something else according to Magnaflow). I had to buy a bunch of other things on Amazon today for Christmas, but the cats are a problem because of when the 94004P can be shipped (I'd like to have this all done soon). The 94004P is also CARB compliant whereas the others are not. They are $65.95 + $10.83 shipping (or $77 total) each, or $144 total for both. The Atlantic British Y-pipe with cats installed is $550 plus shipping I'm assuming, so I'm ahead probably $420 by just buying just the cats.
Search:
http://www.amazon.com/s/ref=nb_sb_no...agnaflow+94004
94004P: CARB Compliant
http://www.amazon.com/MagnaFlow-9400...3719703&sr=8-5
94004: NON-CARB Compliant:
http://www.amazon.com/Magnaflow-9400...3719703&sr=8-1
Oh, I also bought some new o2 oxygen sensors - made by NTK packaged as NGK 25016 12mm which will replace my ERR6729 ones. They were $95 each.
http://www.amazon.com/NGK-25016-Oxyg...3716819&sr=8-2
Anything else I should replace? I think I covered it all, aside from a gasket or two.
Old December 12th, 2011, 07:08 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I just got my Trailhead 4x4 SS Y pipe with Random Tech cats. I cant speak to the performance yet but damn does it look good.
ID:	44653   Click image for larger version
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old December 12th, 2011, 07:25 PM
Those are the smallest cats I've ever seen; is that for the 110 or your 90? I don't see those on their site.
Old December 12th, 2011, 07:30 PM
Reese_D90's Avatar
Reese_D90
Reese
They are for the 110. Trailhead had this already made up but I think they would make up a set on request.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old December 12th, 2011, 07:34 PM
Nice. Yeah, I saw the 2 o2 sensors and figured that out. They look really nice. When are you going to install that puppy?!
Old December 12th, 2011, 07:38 PM
Reese_D90's Avatar
Reese_D90
Reese
Over xmas. I need to decide on the cat back. I am thinking NRP, but I love the Borla on my ST, I just dont think its the right sound for the 110.
1997 D90 ST #1953
2006 Range Rover
1995 D90 ST (sold)
Old December 12th, 2011, 08:18 PM
Those bends those near the outlet look very restrictive.
catalytic converter 97 d90 boisdarc Defender Technical Discussions 2 February 20th, 2007 05:14 PM
Only one catalytic converter??? opinions?? cbass Defender Technical Discussions 7 August 10th, 2005 10:30 PM
Replacment Catalytic Converter chrisvonc Misc. Chit-Chat 5 May 3rd, 2005 06:22 PM
Catalytic Converters and Muffler OCD90 Defender Technical Discussions 1 January 19th, 2005 01:24 PM
Catalytic Converter needed for 94 D-90 ripp2002 Defender Technical Discussions 9 December 15th, 2004 06:43 PM
