Re-build of B777 ONR - Defender Source
Old February 8th, 2013, 02:18 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Should have started with from the beginning so I will start now.
OK, had some time to play with the 90, inserted the rear diff into the axle, bolted on the prop shaft, front prop shaft is like to short? with it fully extended there is a gap of 1.5"
I checked the wheel base and came up with 93.5" which is .5" longer than spec.
Only change to the front axle is, it was from a D1 but the diff is the original 86 year (I think), I ask. Are the diffs different in nose lenght? I don't have the orginal axle tube anymore.
ID:	65905   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 8th, 2013, 10:36 PM
roverman2010
1985 LR 90 200Tdi
Would some kind sole that has a 200tdi-LT77 D90 measure the edge to edge of the front prop shaft.
I am getting a measurement of 28.25" required length
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old February 9th, 2013, 03:15 AM
DBrands's Avatar
DBrands
David Brandson
D90 Truckcab
I measured 28.25" fully extended. Drive shaft just happened to be off the truck. 200tdi/LT77
Fully compressed is down around 26"
Old February 9th, 2013, 05:49 AM
diff nose length should not be different. All defenders with lt230's use the same front prop shaft. How did you use a d1 front axle without changing to the later wide style (better) radius arms too ?
Old February 9th, 2013, 11:30 AM
roverman2010
1985 LR 90 200Tdi
David thanks for measuring
my old front prop shaft that was taken off, tagged & Bagged measures 26" fully extended & 24.25" fully compressed. I had a old DII front prop shaft that I rebuilt and was the same length so was going to use that.
Doug, I just happened resently got a set of RTE offset arms from a forum member, as I could not find a set of the thicker arms local.
Thinking getting those arms,I would be saving getting my balls offset.
With everything snugged up I am seeing a 1 1/8" incline to the rear on the springs, is this right?
I did see the same sort of measurements with the old original arms on.
The only items changed on the front other than a new Marsland chassis is the D1 axle.
Whats up??????????? I am approaching my project budget, soon will be eating into my rollcage money. I have been running Land Rovers for over 30 years now, so I know much of a money pit they can be.
ID:	65953   Click image for larger version
ID:	65955   Click image for larger version
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old February 9th, 2013, 01:40 PM
roverman2010
1985 LR 90 200Tdi
propshaft
Number stamped on original propshaft is 571995, comes out as a RRC early propshaft
why did it fit before?
Is there a differance between 1986 NA diesel to 200tdi chassis?
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old February 9th, 2013, 06:42 PM
Winnet
Graeme
1985 90
I had this issue on my 90 thanks to a 2" lift and the problem was solved by getting a proper 200tdi propshaft.
G
Old February 9th, 2013, 06:47 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I had a similar problem, I had two kids stand on the front of the frame and it seemed to get closer. I'm assuming it will get closer as more of the truck goes back on (more weight up front)
Old February 10th, 2013, 11:17 AM
roverman2010
1985 LR 90 200Tdi
wrong propshaft
Ok, sorted this out, after a few Mardi Gras drinks, I remember when I took off the front propshaft the dust cap was not screwed onto the front splined piece, and I looked at the marks left by the gaitor and this morning confirmed it by looking at pictures I had taken during dismantling. The spline was only 1" into the female end. Who said drink was bad for the memory? Mount Gay and Newcastle brown sort it out again.
Not sure if it was the PO had removed and replaced it with anything lying around, or this is another stolen part by some bastard at Southampton Docks.
Now looking for a correct 200tdi D90 prop shaft.
Would like to add, if you got a 200tdi with LT77 that was converted from NA or petrol and if you haven't done so pull back the gaitor and check the splines are not showing and the dust cap is fitted. Front propshaft
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old February 10th, 2013, 12:04 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Shoot me an email, I have that
Old February 11th, 2013, 04:46 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Early D1's (prior to the 300Tdi era) had the narrow radius arms.
200Tdi 90/2.5 NA had the same propshafts. 300Tdi & V8 (and Td5) defenders are the same length
WTB D90 body parts - Considering a hybrid build. Roving Beetle Wanted 15 February 26th, 2010 12:19 PM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
Sway Bar Disco Build blkdiscoII Misc. Chit-Chat 1 March 6th, 2005 02:10 PM
D90 withdrawl :( 110 build :) evilfij Defender Technical Discussions 6 October 23rd, 2004 01:04 AM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
