Re-assembling a 110 5 door - Defender Source
Old May 27th, 2007, 02:22 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I'm building up my 110 Station wagon at the moment , question is does the rear body go on first or the side frames? I remember it was a PITA to disassemble 3 years ago, involving a great deal of angle grinding and shearing of bolts, but now it's time to put clean galvanised bits back on.
Mike Hammond
Old May 27th, 2007, 07:44 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
From the one I'm doing ...
I removed the door posts before removing the rear tub and bulkhead. So I will be putting the tub back on followed by the bulkhead (left a little loose for further ajustments). Then the door posts and then the top. Make alot of mesurments for fitting the doors properly and getting everything nice and tight. And finish by securing all the fasteners one last time with every thing well aligned.
Just my 0.02$ here I'm no know it all expert but that is what I will be doing next week.
I will post pics in the rebuild threads by the end of this month.
Good luck !
Pat
Kirk Lazarus, Tropic Thunder
Old May 28th, 2007, 04:10 AM
mikeslandrover
Mike Hammond
Thanks for the input, I've already put one side frame on (and had to slacken off prevoiusly tightened bolts to get alignments right), encouragingly the side flare on the bodywork lines up nicely with the bulkhead. I'll hold off fitting the other side frame and try and ease the read tub on from a slightly side on starting point
In reality I'll probably end up taking the side frame off again.
Thanks for the input, look forwarf to seeing the pics
Mike Hammond
Old May 29th, 2007, 02:39 PM
You can do it either way. I tend to assemble everything ie put the side frames (t-pieces) on the tub and then put it on as one piece, but I took the side frames in and out of a 109 without moving anything else so you can do it any way you want.
Old May 30th, 2007, 04:18 AM
mikeslandrover
Mike Hammond
I think the side frame needs to come back off, both of you seem to fit theside frame to the rear tub. it's logical. it's the lighter of the two bits
Pnly 9 nuts and bolts to undo. better than the seat box at around 40!
Mike Hammond
110, door
Help Needed - NAS 110 New Style Door Sill Seals R. Kurk Defender Technical Discussions 14 December 12th, 2008 11:48 AM
110 top, 3-door solid sides, full rear door Method PHX For Sale - Parts 7 March 10th, 2006 04:07 PM
97 D90 SW - Inner rear door panel Kimos Wanted 5 December 2nd, 2004 09:26 AM
» Defender Registry
Big Bird
owen
Oink
Akitatw4
Add your Defender
