Raw Gas Smell/Unknown Part - Defender Source
Old August 4th, 2013, 03:25 PM
minch77's Avatar
minch77
Minch
1997/Defender 90 SW
Exclamation Raw Gas Smell/Unknown Part
Had a raw gasoline smell from fuel tank area on my 1997 D90 NAS. Dropped the tank for inspection and other reasons. I observed a clear hose which appears severed or disconnected. The hose extends from a black plastic box located in the rear wheel well on passenger's side. What is the "cut" hose supposed to be connected with? The fuel vent pipes? I cannot find any diagrams on the websites or in the manual.
Also, I followed the frame rail to the engine looking for the remaining part of this hose but none exists. There is, however, a similar hose running out of the "black box" and to the engine and I assume its the fuel line. The "black box" has a total of three connections and one is the fuel line.
Photos attached.
Q 1: What is that box called?
Q 2: Where does this hose connect?
Q 3: What does the fuel tank vent pipes connect to?
ID:	76918   Click image for larger version
Old August 4th, 2013, 04:00 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
That "box" is part of your "evaporator" system and that hose connects to nothing...it just equalizes pressure and vents to the atmosphere.
Old August 4th, 2013, 04:07 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
What Bill said - and you likely have a leak in the either the breather or fuel filler hose. Probably the former.
-Ren Ching
Old August 4th, 2013, 06:23 PM
minch77's Avatar
minch77
Minch
1997/Defender 90 SW
Thanks for solving that puzzle for me. I will check both filler and breather lines like you said.
One more issue: When I dropped the tank I saw the end of the fuel tank vent pipe was not connected to anything. I figured I may have forced the disconnect as the tank was lowered. What do the fuel tank vent pipes (the end) connect to? Is it one of the hoses coming out of the evaporator box?
gas, part
Fiberglass top tailgate window gas struts part# AmityD90 Defender Technical Discussions 5 October 27th, 2010 10:47 PM
need a part # or info on where to buy part yellowrover Defender Technical Discussions 4 August 3rd, 2004 09:55 PM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
