Rattle From Rear - Defender Source
Old July 26th, 2004, 11:53 AM
Krna
Andy Krna
1997 D-90 ST AA Yellow
Rattle From Rear
I have been having a rattling/clunking sound coming from the rear of the truck. It is most noticeable at slower speeds and over bumps. The noise happens when my rear wheels go over the bumps. I tightened the rear door and the tire on the rear door and it is clear that the noise is coming from under the bed. I went under the defender and checked around and couldn't find anything that is loose. I can isolate the noise by bouncing the rear of the truck up and down when it is parked. Anyone have any ideas before i take it to the shop (where i am sure they will say that nothing is wrong or they cant find the noise)?
Andy
Old July 26th, 2004, 12:21 PM
Well if you are sure it is not the rear tire carrier (I have thought that there was something under rattleing only to find out it is the rear tire carrier), then I would get under there and grab and shak any of the suspension parts. If you can reproduce it by having someone jumping in it while you look around under it I'm sure you will be able to find it.
Old July 26th, 2004, 01:40 PM
Abrooks's Avatar
Abrooks
Tony Brooks
check your shock bushings.
Old July 26th, 2004, 11:50 PM
XD90's Avatar
XD90
James Morgan
1986 Ex MOD XD90
hi
check your rear propshaft UJ, the rear shockers and the rear bushes mabye even your tow hitch if ya have one that is
James
rattle
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
SW Rear Door Rattle seattlejanzen Defender Technical Discussions 5 November 5th, 2003 10:25 AM
