Rattle down under - Defender Source
Old July 9th, 2004, 03:41 PM
benh
Benjamin Hillegeist
97' d-90 ST
Rattle down under
Hey guys, can someone help me out ASAP? I have my d-90 over at British 4x4 in Mission Viejo b/c of a rattle from underneath. When I am pulling up to light, slowing down etc.. there is a rattle from underneath. They believe it is a heat shield or my cat conv. any thoughts? cost + labor? I need some ammo in case this is gonna be a big fix!!
Pedro, you can use my skills
Old July 9th, 2004, 03:53 PM
If it is the heat shield my guess is the welds broke. Have them weld it back on shouldn't be more then $50 (at leats not around me). But normaly when a cat rattles it means the internals of the cat have goon bad. Then you are into more $$$$.
Old July 9th, 2004, 03:56 PM
benh
Benjamin Hillegeist
97' d-90 ST
$$$ of a new cat?
Old July 9th, 2004, 04:09 PM
Not sure some info here
http://www.defendersource.com/forum/...ead.php?t=2230
Old July 9th, 2004, 05:06 PM
benh
Benjamin Hillegeist
97' d-90 ST
i just read about a guy who used the summit universal cat on a fix. Does anyone know about CA emissions with one of these in place?
Or is re-builing the cats out here a legal option to spending the $600 on anew cats and a Y pipe?
Old July 10th, 2004, 01:43 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Could this be a u-joint problem? My D90 makes a noise when decelerating from highway speeds. Sort of sounds like when you are off the shoulder on those grids.
Old July 10th, 2004, 02:50 PM
prospector
Brian Rekasis
95 d90
i just experienced the exact same symptoms. the diagnosis was the cat converter in the y pipe was falling apart. i was told i need to replace the entire y pipe which is not cheap. there's also nothing wrong with just letting it contiue to rattle.
Old July 10th, 2004, 06:43 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Northwest Rover Performance Stainless will cure it.
EwS
Old July 12th, 2004, 03:06 PM
benh
Benjamin Hillegeist
97' d-90 ST
Talking
Nixed and fixed, I just picked up my d-90...Cats were fine!! What the dealership told me would be around a $1200 fix, Brtish 4x4 did for $285.00! If you are in So Cal. and need service I highly reco. these guys. Joe got her fixed in no time flat...They were chep, quick and best of all honest.
rattle
Window rattle D90user Defender Technical Discussions 4 February 2nd, 2006 11:23 PM
Rattle noise from distributor? hmmmm Davis Defender Technical Discussions 5 June 13th, 2005 10:39 AM
95 S/T Rattle Help? rcmorgan540 Defender Technical Discussions 7 June 10th, 2004 11:33 AM
Window rattle ? Hammertime Defender Technical Discussions 3 April 13th, 2004 04:08 PM
Back Door Rattle mdmccallum Defender Technical Discussions 7 December 19th, 2003 12:55 PM
» Defender Registry
"Barney"
GriffCA
KT
rkinsk
Add your Defender
