Ratio numbers - Defender Source
Old June 12th, 2012, 11:03 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Ratio numbers
Looking for info from anybody running the following..
4.11's - 1.4 t-case and 34-37" tires, based on actual measurement
RPM/MPH - highway speeds
Thanks!
Old June 12th, 2012, 11:08 AM
You may be able to use the Ashcroft online calculator
http://www.ashcroft-transmissions.co...atio_calc.html
or
http://www.rocky-road.com/calculator.html
Old June 12th, 2012, 11:38 AM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Thanks Josh I have used the Ashcroft calculator but was also hoping to get some real life numbers from somebody who has drove that set up on the highway. I just picked up a 1.4 I will be rebuilding and hold onto until my current t-case bites the dust. Wondering if the 1.4 is going to be too tall for anything under 36-37".
Old June 12th, 2012, 04:13 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
4.11 + 1.4 on 35" is too tall ( I ran that for a weekend when I blew my TC and needed a replacement). On 37" it should be nicer. Jarek was technically running that in his Disco when it was a V8. He had 4.75 + 1.2 which is equivalent and he is on 37" tires. Ask him - http://njlr.org/forums/viewtopic.php?f=7&t=24
He has 4.75 = 1.4 running a Mercedes 300d engine in there now so its a bit different.
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old June 12th, 2012, 06:05 PM
Jake1996d1's Avatar
Jake1996d1
Jake
96 Disco/88 RRC
Thanks that was what I was looking for. I'd like a little bit more get up and go on the hilly 45MPH back roads but dont want to completely lose driveability/top speed on the highway. I will likely end up with 37's for my next set on this truck anyways so I'll slowly rebuild this case. Thanks!
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Vehicle numbers shawom Misc. Chit-Chat 4 July 21st, 2005 01:42 AM
Gear Ratio Calculator norros Misc. Chit-Chat 0 June 26th, 2005 10:54 AM
1.4 ratio transfer case dave_lucas Wanted 2 November 13th, 2004 02:16 PM
rivet part numbers? mattdh Defender Technical Discussions 0 October 29th, 2004 03:09 PM
