Range Rover County Ignition Problemss - Defender Source
Old August 28th, 2005, 07:36 PM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
Hey Guys
I have been having some problems with my ignition lately...the steering wheel is locked and I am unable to turn the key. Has anyone had anything similar happen to them? If so, how did you remedy the problem?
Old September 1st, 2005, 12:05 AM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
any help would be greatly appreciated....
Old September 1st, 2005, 05:51 PM
Put it in neautral release the park break and let it roll a little to free up the steering wheel and you should be able to turn the key. It has happened to me before.
Old September 1st, 2005, 05:55 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Has this been sitting in the same place for days just 'cause no one answered this? Try rocking the steering wheel back & forth slowly while turning the key buit don't break the key off.
Old September 1st, 2005, 06:11 PM
Wait does this have a slush box? If so then maybe the park solnoid is broke.
Old September 9th, 2005, 01:35 PM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
I have tried everything...rocking the truck back and forth...moving the wheel back and forth...stepping on the brakes...you name it, I have tried it. I am pretty sure the lock cylinder is shot...have heard of this happening before with the older Countys...
Any other suggestions?
Old September 11th, 2005, 07:51 PM
Spray it with some WD-40? SOmetimes after a few rain storms mine get's a little corroded and this helps. Are sure it is in park? Have you checked the park solinoid?
problems, range rover
Famous Land Rover owners Lindy Misc. Chit-Chat 4 June 15th, 2009 08:49 PM
Good Bye Ford, Hello Tata... It's done. JFD Misc. Chit-Chat 46 April 3rd, 2008 02:49 PM
Land Rover family tree D901619 Defender Technical Discussions 9 July 5th, 2007 04:34 PM
1990 Range Rover County stock/never offroaded jack frisch For Sale - Vehicles 0 February 21st, 2005 06:00 PM
