Range Rover Classic ignition removal - Defender Source
Old September 26th, 2016, 07:24 PM
signalMTB's Avatar
signalMTB
Rusty
'97 NAS D90 / '94 RRC / '05 L322
There's enough guys on this forum who have classics and/or have parted out these trucks. I am removing the ignition from my '94 classic and I've been reading that you have to chisel out the two bolts that hold it to the steering column. Take a look at this picture, is this what you guys normally see? The bolt heads seem to be recessed down in there and I can't get them to move with a chisel. Some have had success with a Dremel tool, but I'm curious if Those who have done that had the bolts recess down in there like this. My other option I guess is just break it off somehow because I'm not planning to reuse the ignition.
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
many others that have sold
Instagram: @SecondDailyClassics
Old September 26th, 2016, 07:30 PM
ezzzzzzz
Mark Garrenton
'71 IIA 88 LS1 coiler, '84 110, +++
If you've got access to a dremel just notch the heads. Cutting into the top bracket won't hurt it's integrity. If you try to break it you'll probably just damage other stuff you want to keep. That's how my luck goes anyhow.
Retirement is great, I haven't missed a day yet!
Old September 26th, 2016, 07:45 PM
signalMTB's Avatar
signalMTB
Rusty
ok, yeah, I see where your blade cut just a little bit into the one you sent and those bolt heads look to be quite recessed. I'll go pick up a dremel tool tomorrow.
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old September 26th, 2016, 08:30 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
yes, cut a slot-then a regular flathead screw driver will do it ezzz peasy.
ID:	158463   Click image for larger version
Rent my
Old September 27th, 2016, 07:34 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Add Dremel to the ultimate travel spares kit.
Old September 27th, 2016, 08:51 AM
signalMTB's Avatar
signalMTB
Rusty
well that was a t-total pain in my rear...but the new one is in and all working well (except my rear wiper arm which may or may not be related to this...it was acting up awhile back, will have to look into that later).
thanks ezzzzzzz for the ignition.
if anyone needs an old ignition with range rover key, let me know. free just pay shipping. it works, but it doesn't always stay in the II position so sometimes when starting it'll turn back by itself. I don't need, I'm tossing it if no one needs it or wants it for spare parts (or maybe to rebuild the tumblers).
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old September 27th, 2016, 09:39 AM
Probably could have gotten away with just the ignition switch instead of the whole barrel (and kept original keys etc.) based on your issue description, but it's too late now
Old September 27th, 2016, 10:13 AM
signalMTB's Avatar
signalMTB
Rusty
I think you're right, I was thinking this was more a sure bet thing rather than replacing pieces parts.
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old September 27th, 2016, 10:15 AM
Yeah the switch is the most common failure since it's basically just plastic, copper and glue
Old September 27th, 2016, 10:16 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Stephen, are you parting out a RRC?
Does it have the rearview mirror with maplights on the bottom?
If so, I'm looking for one...
Rent my
Old September 27th, 2016, 10:38 AM
signalMTB's Avatar
signalMTB
Rusty
no sir, but forum member @brentflyfish has a '95 he's parting out.
and this guy (Parting 1995 RRC LWB Roman Bronze - Land Rover Forums - Land Rover Enthusiast Forum)
'05 RR L322 HSE
'94 RRC LWB
'97 NAS D90
Old September 28th, 2016, 02:34 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
When I used to work on ignition locks, I simply used a sharp edged flat ended punch and a hammer.
Turn the punch at an angle and let it's edge cut into the perimeter of the head by using a hammer to screw out the shear head bolt.
If I had to reuse the bolts, I'd cut a slot in them with a hacksaw, reinsert and cover the heads with liquid steel flush with the die-cast housing.
Old September 28th, 2016, 02:37 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Thanks- I think I already posted on Brent's thread-I'll check the other one out!
Rent my
classic, range rover
TWR Classic :: 1995 Land Rover Range Rover Classic griffinrr Defender & Series Truck Registry 0 January 4th, 2016 07:13 PM
FOR SALE: 1989 Land Rover Range Rover Classic (lifted) Rovercox For Sale - Vehicles 33 May 28th, 2014 09:44 PM
Ignition steer Lock removal Nate6472/ Defender Technical Discussions 5 October 6th, 2013 10:50 PM
Cigar Lighter Removal and Rear Wiper Switch Removal isleofbones Defender Technical Discussions 6 April 13th, 2013 08:02 PM
