Range Rover Classic Factory driving lights not working - Defender Source
Old November 23rd, 2014, 09:51 PM
RANGEROVERSURFER's Avatar
RANGEROVERSURFER
Tony
95/Range Rover Classic
Factory Driving lights are not working. when I push the #2 driving light switch, there is no illumination on the switch. the lights are not working, checked and replaced the fuse for the driving lights.
Is there a relay? I also checked the connections both blue and black wires are connected.
is it possible the the switch is bad? I don' think both lights are bad.
any and all suggestions appreciated.
Tony
1995 RRC SWB Chawton White
1990 RRC SWB Eastnor Green
1990 RRC SWB Mettalic Blue
Old November 24th, 2014, 12:07 AM
Greg S
Greg Sutfin
1986 90
I trust you have the headlights on and on high beam when you are trying it. Right?
Fog light work when headlight low beam is on and driving lights only work when high beam is on.
ac, classic, factory, ht, lights, range rover, vin
silly electrical system-Haz lights not working El Solis Defender Technical Discussions 16 October 15th, 2014 09:07 PM
LED front lights not working D904evr Defender Technical Discussions 8 August 29th, 2013 07:34 AM
Brake lights not working FlaD90 Smaller Projects 3 August 18th, 2008 04:29 PM
top warning/indicator lights not working draaronr Defender Technical Discussions 2 May 22nd, 2008 07:43 PM
'95 Factory Radio Fade/Treble/Bass Button Not Working gamberik Defender Technical Discussions 1 March 30th, 2005 01:05 PM
