Random question.. Does the 95 NAS have a speed limiter? - Defender Source
Old December 29th, 2015, 09:15 PM
Mine seems to cut ignition briefly at ~95 mph indicated. A scan of the 14CUX manual didn't net anything, ideas?
95' D90 - daily driver..
Old December 29th, 2015, 10:48 PM
yes
http://www.defendersource.com/forum/...ped-48284.html
Old December 29th, 2015, 10:52 PM
Ok that's good, does anyone have a manual with it documented?
Old December 30th, 2015, 09:45 AM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
The fact that you had the courage to get your Defender up to 95 mph is worth applauding! I have had mine up to 80 mph per my Lowrance GPS (showed a just under 90 on speedo) and with the skinny 7.50 x 16 tires I have and no rear sway bar I felt any more may not end well!
Old December 30th, 2015, 10:11 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Originally Posted by rijosho View Post
The thought that someone felt it necessary to remove the 95mph governor.....
Old December 30th, 2015, 10:27 AM
I thought it had 3: atmosphere, gravity and physics
Mark Kellgren
KM4BOR
Old December 30th, 2015, 10:55 AM
Actually felt fine up to an indicated 100 mph (actual is less for my truck) Interesting thing is it only seems to happen when pushing through 95mph, then doesn't happen again. I'm not running sway bars f/r but I did use to drive rally cars / autoX / race so use to a bit of vaugueness
Old December 30th, 2015, 10:59 AM
My suggestion, as others expressed above, is don't do 95mph in a Defender. Ever.
Old December 30th, 2015, 11:08 AM
Rommel's Avatar
Rommel
Rolf
94/95/97 Many
95mph
With a 50mph tailwind ?
rolfsauto.com
Old December 30th, 2015, 11:36 AM
haha.. no it's a NAS 3.9 V8 and it will do 100 mph indicated - takes a while though to go from 85-100 mph and be relatively flat.
mine actually runs really good, most of my Highway cruising is done at an indicated 80-85 mph the actual is in the 70's since my speedo reads fast by about 8mph.
Old December 30th, 2015, 04:22 PM
VictoryWithFlair
Andrew Wolfe
1993 NAS 110 #222/500
I don't think I could hit 100 unless I drove it off a cliff.
Old December 30th, 2015, 05:37 PM
it can be done. This D was snapped as it passed 90mph and still accelerating
Mark Kellgren
KM4BOR
Old December 30th, 2015, 05:40 PM
I do stand corrected...with terminal velocity at around 122mph, I suppose it is possible or a D to go faster than 95.
Wussies. I always swap out the chip or computer for a disco/RRC one to eliminate the 89mph governor. A stock NAS D90 is perfectly stable at that speed. It is as loud as being in a tent next to a jet and fuel consumption is in the single digits, but if properly maintained it is fine. Of course, not recommended and I don't do it anymore.
Old December 30th, 2015, 05:52 PM
sherpamike's Avatar
sherpamike
Mike Doligalski
'95 D90 ST
FWIW I seem to recall that mine would cut out around 85 mph. Used to get there often and and often wanted to go faster in traffic.
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Rob I'd like to see you going 95 down hwy 12.
I've maxed it a few times. It's realllllylyyyy loud.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old December 30th, 2015, 05:58 PM
Actually...I now think that Rob does go that fast in his 90, with that "diesel bomb glint" in his eye. The man is an animal I tell you! Ripping out phones, urinating on desks...did you see what he did to Ms. Cochran's shirt?
Old December 30th, 2015, 06:49 PM
doktorno
Chris deZ.
1995 Defender SW
Only way I managed 85 GPS speed was drafting about eight feet off the rear bumper of a Ford Raptor.
Old December 30th, 2015, 07:29 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
He drives that fast when he thinks some clowns are in his tail.
1995 Defender ST
1996 Discovery SE7
Old December 30th, 2015, 07:39 PM
Slappy and the gang say "You think that's funny? Bring it yotch!" PS they all have concealed weapons (water and bullets)
Mark Kellgren
KM4BOR
Looking to get past the speed limiter... PMKColorado Defender Technical Discussions 22 October 4th, 2016 08:57 PM
NAS AC wiring question or call it a random wire question bjf Defender Technical Discussions 7 May 5th, 2009 09:58 AM
rev limiter rover4x4 Misc. Chit-Chat 3 May 27th, 2004 09:04 AM
Help Speed Limiter evilfij Misc. Chit-Chat 10 May 7th, 2004 10:04 AM
