Random charging issue - Defender Source
Old December 29th, 2015, 12:53 PM
I have a 94 classic with 4.2. For all intensive purposes the same exact setup as the 93,94,95 NAS trucks. I was recently 85 miles from home and the charge light came on. I tried the usual like revving the engine and the light stayed on. I was able to drive all the way home through the mountains with headlights and wipers on. The next morning I put a new alternator I had from Rovers North on the truck. When I hooked the battery back up that alternator made a hum. I started the truck and the light went out and I turned it off and the hum was gone. Its been 4 days and the truck still starts and runs fine but I have another problem. I have twice now gone out to the truck and found the charge lamp on when the truck wasn't running. Its got me buffalo'd. The truck still starts and runs but seemingly if the light is on I'm discharging ?
Old December 29th, 2015, 01:52 PM
xjahx's Avatar
xjahx
JAH
'93 NAS 110, '94 NAS ST, '85 90 PU
-Does the voltage of the battery drop over the period that this light is on without the truck running? Sounds like it would be discharging as you suspect.
-Easy solution, install a battery kill switch but that does not address the problem.
-And as with 99.9% of all electrical issues on these trucks, check for a bad ground.
Old December 29th, 2015, 03:13 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Check the battery terminals; my truck had a bolt through a weld terminal and that caused a charging issue
Old December 29th, 2015, 03:21 PM
Alternator is grounded as it is bolted to the block. Battery terminals in good condition as battery is also new. I haven't left the truck unattended long enough to see if this malady will discharge the battery, yet anyway.
Old December 29th, 2015, 03:35 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Diode in the alt? This is exactly how mine failed on my 200tdi.
Ryan
84 110SW County LHD
07 L322 Vogue
Old December 29th, 2015, 03:42 PM
I'm thinking it is a diode or short in the new alternator, called Drew and he concurs.
Calling Zack....
Old December 29th, 2015, 05:57 PM
Does the 94 have the fusible links? Those go bad too.
Old December 29th, 2015, 07:19 PM
Yes. Have replaced the one to the heater. Fusible links kill power not turn on warning lights
Old December 29th, 2015, 08:46 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Here's how you verify.
Disconnect the battery ground and hook a light bulb between the ground terminal and the (-) battery terminal.
If the light glows (usually every so slightly) you have a diode or charge circuit short.
To verify disconnect the alternator and if the glow is gone you have a bad diode for sure.
The bad news is that if you have installed a 3rd alternator and the same issue persists, then you have a grounding issue or short that is accelerating diode failure, muthalikka.
RDavisinVA
Old December 29th, 2015, 09:05 PM
who ?
Old December 29th, 2015, 09:49 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You had to ask!
Guess who?
RDavisinVA
2.8 charging issue Overlander Defender Technical Discussions 4 July 20th, 2014 05:35 PM
Charging AC in a 97 artm Defender Technical Discussions 2 August 18th, 2009 11:33 PM
UPS charging customs duties and brokerage charges cgalpin Misc. Chit-Chat 7 November 26th, 2008 09:09 AM
Dual Battery Charging RBees Defender Technical Discussions 5 January 4th, 2007 08:51 AM
Battery Charging chris snell Defender Technical Discussions 3 November 29th, 2006 12:20 PM
