Rancho, OME, and Bilstein? - Defender Source
Old August 28th, 2005, 01:30 PM
boshea's Avatar
boshea
Brian OShea
1995 Defender 90 ST
What do you guys recommend and why?
Old August 28th, 2005, 03:07 PM
Seriesman's Avatar
Seriesman
Michael Elliott
1997 D-90 Hardtop (#2369)
Brian,
I just switched from the Rovers North HD kit with Bilstein shocks to the OME kit which came with the matching OME shocks (N45 front; N46 rear). This is of course a personal preference thing, but I like the OME set up much better. For my taste the Bilsteins were too stiff. After I took them off the D-90 I compared them side by side. They were almost exactly the same length, but the Bilsteins were at least three times as hard to compress by hand. They rode fine and I can't complain, its just that I feel the OME ran much better.
Michael
Old August 28th, 2005, 03:14 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
very vague question. What do you plan to do with the rest of your suspension? If you want to run a 3-link system and/or cones, you will can't use OME as they are not long enough. If that is your plan than I would recommend Bilstein 6100 or 7100. If you plan on just lifting the truck and keeping your springs retained use the OME.
Old August 28th, 2005, 04:17 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
David is correct. I have the Rancho 9000's and I like them because they are not expensive and are adjustable for stiffness
Legend in My Own Mind.
Old August 28th, 2005, 07:10 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
I recommend a 7" lift with 5" springs, 2" spacers, Original LR factory shocks (you'll have to move the top mounts down a bit) but you shouldn't touch your driveshafts. Always drive in 4 Low with the Diff Locked to avoid unpleasant vibrations. Then run BFG AT 235/85's because we don't want to look like a chopped up Jeep. When offroading (but you won't be off roading so you can charge $35,000 for you D90 when you sell it, right?) just use snow chains. I get mine from Wal-Mart. Your next mod should be putting in a td5 or the new td6 diesel engine, since each Land Rover NA dealer is fully equipped to service these engines.
There are no stupid questions, just stupid answers, and I hope mine wins.
Old August 28th, 2005, 07:47 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
So far Dave yep you win for stupidist answer
Jimmy Buffett
Old August 28th, 2005, 08:05 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
all in good fun
bilstein
Bilstein Steering Dampner SPIKE Defender Technical Discussions 20 June 22nd, 2009 11:13 PM
OME Springs and Bilstein Shocks set CDeWan For Sale - Parts 3 November 10th, 2008 08:27 PM
Bilstein or OME? Santiago Defender Technical Discussions 17 September 3rd, 2008 09:31 PM
Sliding down the slippery suspension slope souza Defender Technical Discussions 18 February 3rd, 2005 11:06 PM
OME installation... greend90SW Defender Technical Discussions 18 March 18th, 2004 10:55 PM
