Ran out of gas...refilled and won't start..HELP - Defender Source
Old July 3rd, 2013, 12:45 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Just ran out of gas...I know what jackass runs out of gas....was fortunate enough to coast into my local gas station where I buy 93 octane 100% gas (ethanol free). After refilling...won't start and stay running. Only runs for about 5 sec. Mechanic sprayed some gunk cleaner and it would run as long as he sprayed...as soon as he stopped truck would stall. Can hear my relays clicking on the fuel pump. They're gonna try flushing out the fuel filter with compressed air....hope this works. Mechanic thought it may be the fuel pump....randomly went out the same time I ran out of gas? thanks for any insight
Old July 3rd, 2013, 12:47 PM
You could have just been low on fuel, and the fuel pump failed.
Old July 3rd, 2013, 12:59 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
First verify that the fuel pump is running. If it isn't then its probably not a coincidence that it crapped out. When you run your truck till it runs out of fuel the last thing that went through your fuel pump was any sediment that was on the bottom of the tank. Running it dry and sucking that sediment could've been what killed your pump.
Old July 3rd, 2013, 01:21 PM
Can you hear the pump running for a few seconds when you turn on the ignition?
Old July 3rd, 2013, 01:27 PM
Could you have run the line dry and now have an air bubble?
Old July 3rd, 2013, 01:34 PM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
I hope you solve the problem fast! My brother was impressed when he saw your truck in Blacksburg!
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old July 3rd, 2013, 01:40 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
There's was a lot of background noise...I removed the seat and could hear the relays clicking but I'm not sure if I could hear the pump....I'll check and see if I can hear it. fishEH...thats what I'm afraid of! woldd90...that would be great.
its been a little while since I've posted anything due to starting a business....I absolutely love this site...thanks for all the help guys!!!
Old July 9th, 2013, 10:37 AM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
NO power to new fuel pump.
New fuel pump...but no power. I'm pretty certain my silver bosch relays under the passenger seat are fine. Why aren't I getting power to the pump?
Old July 9th, 2013, 10:40 AM
disconnect the battery ... it will reset the ECU ... send me paypal as thanks! ;-)
Old July 9th, 2013, 12:22 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Reset ecu....still no power to the purple/white wire to fuel pump
Also no power to the blue/white wire to this. Is this the fuel pump kill switch?
What's next?
Old July 9th, 2013, 12:46 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
The pump was actually fine. But the mech can't get power to the pump....he thinks it has something to do with the switch pictured above.
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
yes .....Inertia Switch ... jump the switch will eliminate that idea
check the fuel pump relay for power should have 2 legs of power one from ecu with key turned on and steady power on the other leg
fuel pumps do not like to be run dry especially rover ones ...
No Mall crawler here
Old July 9th, 2013, 12:55 PM
Have you checked the fuses ?
Old July 9th, 2013, 01:00 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
The fuse to the fuel pump doesn't have power. He replaced the fuse...and he showed me when he put a tester on the fuse there was no power.
Old July 9th, 2013, 01:24 PM
So the fuel pump only gets brief power when you first turn on the ignition ...
Fuel Pump Relay
The fuel pump relay is located next to the main relay. The ECM provides power to the fuel
pump, HO2S heaters and purge valve through the fuel pump relay. The ECM operates the fuel
pump for one second at key on and then when it senses a crank/run signal from the ignition
system
see this document page 89
http://p38arover.com/rover/p38a/Engi...UX_Systems.pdf
Old July 9th, 2013, 01:38 PM
psykokid
Jake
1997 Disco
Try jumpering the fuel pump relay and see if that gives you power to the fuel pump.
Old July 9th, 2013, 01:45 PM
It will only run for 1 second to prime the fuel rail pressure ...
Old July 9th, 2013, 01:55 PM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
If you haven't seen it already, see post below:
http://www.defendersource.com/forum/...uel+pump+stops
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old July 9th, 2013, 04:06 PM
psykokid
Jake
1997 Disco
Under normal operations yes, most modern EFI systems do this until the ECU receives an input signal that the engine is cranking.
What i'm talking about doing is making a jumper wire to connect the hot terminal (term 30, purple wire/white tracer) of the relay socket to the fuel pump lead (term 87, white wire/purple tracer) to bypass the relay and test that way. Test with a volt meter first to make sure you are getting power to the fuel pump relay. The ECU turns the fuel pump on and off via switching on/off the signal legs of the relay, not the hot and load side of the relay.
Old July 9th, 2013, 04:26 PM
Quimbola's Avatar
Quimbola
Josh
1994 #1695 Not stock.
Oddly enough my boat (ford gt-40 engine) had the same problem, turned out the relay was bad, even though it was "clicking" with the ignition, jumped the relay and pump fired...bad relay.
