Ram housing removal - Defender Source
Old March 25th, 2013, 10:18 PM
scolvus.x
John Lomax
94 ST
Ram housing removal
After the good advice yesterday I'm to the point of removing the ram housing (as part of replacing my injectors.
It is truly stuck on. I found a suggestion to hit it with a dead low, which I've been trying for over an hour. I also cannot access the corners to pry because of clearance around the fuel rail.
Any other tricks to get this thing off?
Old March 25th, 2013, 10:52 PM
The plenum ? Are you certain you have all the bolts out ? Never had to hit one more than a couple times with a rubber mallet.
Old March 25th, 2013, 11:18 PM
scolvus.x
John Lomax
94 ST
Yes the bolts are out. The plenum cover came off after a few hits with the dead blow. But the ram housing beneath it is a different story. It seems like the last person in used a black silicone to re-seal it. The stuff is like concrete now.
Old March 27th, 2013, 08:22 PM
scolvus.x
John Lomax
94 ST
Well, found a solution that worked really well. Took a piece of 2x2 oak, and cut a 4" long section. Resting it on the block between injectors 1 and 2, used it as a leverage point for my pry bar. Came off no problem.
In situ gear selector housing removal michael67 Defender Technical Discussions 4 September 25th, 2011 12:34 AM
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
How to get d--- fuel pump housing back in NAS tank? Chris Cox Defender Technical Discussions 3 October 29th, 2004 09:58 AM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
