Rally Light Wiring: ROUTE THROUGH ROLL CAGE - Defender Source
Old October 18th, 2008, 03:31 AM
pcscharfe
pcdefender
D90/NAS 110
Thumbs up Rally Light Wiring: ROUTE THROUGH ROLL CAGE
I have 4 Hella 3000's mounted to tabs on my factory roll cage. I am tired of looking at sagging wires and zip ties. I would like to drill into the cage and route the wires through and into the engine compartment -- but wanted to get advice from you guys first.
Has anyone done this successfully?
What steps did you take?
Special tools required, etc.?
Any pics?
I found this old post but was hoping for a bit more insight from someone who has done it.
Originally Posted by javelinadave
I have seen people who have drilled a hole behind each tab and ran the wires thru the rollbar. If you do it the second way, you are going to have to remove the front part of the cage and drill a hole thru the inside of the fender to get the wires out of the roll bar. I hope I have not confused you with this explenation. I wish I had some pictures of the thru the bar thing. Good luck.
Thanks!
Paul
Old September 8th, 2009, 03:35 PM
tebby's Avatar
tebby
Justin Tebbenkamp
95 D-90 ST
Has anybody done this? Where is the best place to run wires from engine bay into cab?
Old September 8th, 2009, 04:15 PM
If you can take off the cage, and run the wires down the drivers side, then you can run the wires into the cab through the existing hole in the firewall, behind the instrument cluster.
cage, ht, wiring
snaps missing in roll cage jaherring Defender Technical Discussions 4 March 17th, 2008 11:23 AM
D90 Roll Cage - Centre loop + Rear Cage MDS For Sale - Parts 7 December 13th, 2005 12:20 AM
D-110 Roll Cage Again... roverboy Defender Technical Discussions 13 November 27th, 2005 01:05 AM
95 Defender 90 frame and ST roll cage crobinson For Sale - Parts 6 November 24th, 2005 12:46 PM
NAS roll cage archoid2 Wanted 6 October 31st, 2003 07:28 PM
