Raising bulkhead off of frame - Defender Source
Old January 5th, 2013, 03:39 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I need to raise my bulkhead/body about 1/2" off the frame in order to get the chassis harness through the gap between the passenger outrigger and bulkhead. I forgot to have them leave the plugs off of the harness (where it connects to the main harness) when I ordered it and it's not going to fit through the gap with the plugs on.
I figured the I would remove the large bolt that connects the passenger side outrigger to bulkhead and loosen the nut on the drivers side. Then I'd use a 4x4 on top of a floor jack to raise the bulkhead up just a bit.
Am I missing something? I don't want to bend the bulkhead or body doing this.
Old January 5th, 2013, 04:00 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Can't you lube up the loom with something slippery and slide the actual cable through the gap, instead of the plug?
But yes, if you undo the big bolt, AND the support bracket that bolts onto the back of the footwell, then you should have enough give in the wings and floor plates to use a hi-lift under the corner of the bulkhead to just lift it up a little bit.
Old January 5th, 2013, 04:54 PM
chris snell
Chris Snell
87 Ex-MOD 110
Unfortunately, the plugs are at least 1/4" too big for the gap. What I should have done is order the harness with the plug inserts (the wire terminals) already crimped on and insert them into the plug shell once the harness wire was passed through. Hindsight...
On a positive note, I found a source for 1994 engine harnesses, brand new, made to order. I'll post a write-up on that later, once I finish this.
Old January 5th, 2013, 04:57 PM
Why not just route it next to the transmission and tcase? There should be plenty of room when you remove the tranny tunnel?
Old January 5th, 2013, 06:38 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
You are going to twist a lot of things trying to lift one side of the bulkhead a 1/4". Rollcage, wings, seatbox, tub, etc are all interconnected in one way or another. Take the floor plate out and the tunnel out. I'm sure I've done this a couple of times with everthing in situ.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old January 5th, 2013, 06:58 PM
chris snell
Chris Snell
87 Ex-MOD 110
The harness routes out of a hole in the frame and then up over the frame outrigger, across a small section of the wheel well and up into the engine bay. There is a branch that runs over to the t-case/gearbox are but that's not what I'm having trouble routing. There's not enough slack built into the harness to route it any other way.
I either need to figure out how to raise the bulkhead enough to squeeze the plug through or I need to clip toff the plug and install a new one, and hope that I have enough slack to do this.
Old January 5th, 2013, 07:43 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Bulkhead is also tied in from the frame to the floor with 2 bolts on each side. I do not understand where the issue is take a picture and post it.
Old January 6th, 2013, 04:56 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
How about taking the plugs off? they go both ways and would seem to me a bit easier than lifting the frigging bulkhead up.
Matt Browne
Old January 6th, 2013, 10:05 AM
rovertrader's Avatar
rovertrader
Dale
Reread Chris' H's suggestion- we have done it that way numerous times as well
Old January 9th, 2013, 05:10 PM
chris snell
Chris Snell
87 Ex-MOD 110
So here's what I'm looking at. Removing the floor plate and tunnel would not help with my problem. I'm having trouble getting the very end of the harness over the outrigger and into the engine compartment:
http://www.flickr.com/photos/defende...in/photostream
As you can see in this photo, the gap lies in between the bulkhead and the outrigger. The floor plates are to the rear of the gap:
http://www.flickr.com/photos/defende...n/photostream/
The plug is just a little bit too big. Maybe 1/8 - 1/4" tops:
I'm just trying to avoid chopping this harness up. If I could raise the bulkhead 1/4" and then lower it back into place, I'd be done.
Old January 9th, 2013, 05:17 PM
MUDSUX's Avatar
MUDSUX
Forrest
Like my Tatas?
Hey Chris,
Have you tried looking inside the harness to see if there are little clasps that will release the individual metal prongs? I have had good luck with most electronic plugs like that. Just press on the little clasps and the wire will just pull out. Worth a look, maybe you'll get lucky and that plug works like that too.
MUDSUX
Take the tunnel and floorboard off and it will be fine.
Old January 9th, 2013, 05:21 PM
chris snell
Chris Snell
87 Ex-MOD 110
Shit, I think I finally understand what you're getting at. So I would remove the floorboard and tunnel, then pull the harness over those brake lines and then forward of the outrigger, at which point I only have to move the wires over the outrigger, not the plugs?
Old January 9th, 2013, 05:24 PM
Yup!
Old January 9th, 2013, 05:26 PM
chris snell
Chris Snell
87 Ex-MOD 110
Thanks. Shit. I was stuck on this idea that the harness had to go over that outrigger and never considered going around it.
Old January 9th, 2013, 05:46 PM
great success!
Old January 10th, 2013, 02:38 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
That is one clean chassis and underbody!
Water Leak bulkhead to windscreen frame seal JackDEF90 Defender Technical Discussions 24 September 27th, 2012 06:09 PM
Defender windshield frame mounted to a 109 bulkhead, same? mightymg Defender Technical Discussions 1 April 28th, 2010 10:14 AM
How straight is a typical Defender frame? madcowdungbeetle Defender Technical Discussions 9 August 22nd, 2009 05:43 PM
Seals between windshield frame and bulkhead and roof bjf Wanted 7 May 18th, 2009 06:20 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
