Rain coming in the back of my 97 D-90 ST - Defender Source
Old December 11th, 2008, 03:09 PM
wadaman
Glenn Wada
97 D-90 #1257
There is a 1.5 inch gap where my soft top leaks into the back of my D-90, just over the swinging back tailgate.
Any way to address this in an attractive manner, or am I missing a part off my soft top? Just picked up the truck a month ago...
GW
Old December 11th, 2008, 03:15 PM
Search "tailgate bar" do you have that?
Ron
PS no luck finding that hella 3000. I found two hella 1000s, a pair of 4000s and a bunch of IPFs, but no 3000s.
Old December 11th, 2008, 03:34 PM
Last time I checked... Hella still had a stock of 3000's.
Old December 11th, 2008, 08:11 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
The stock Bestop does this - very typical. A badger top is much better as there are a couple inches of extra fabric that fold back when you close the door which prevents a gap.
That being said, these trucks leak. I just drove mine with the surrey on through a rainstorm today in Florida. As long as you don't stop the rain doesn't really get ya!
Old December 12th, 2008, 08:23 AM
The PO of mine had the rear of the top lengthened slightly by adding a bit of material just below the window. It's hardly noticable.
Which reminds me, I need to find a piece of scrap material like the tickford top material to make a repair.
Old December 12th, 2008, 12:57 PM
aosias's Avatar
aosias
Alexandra
1995 D90
I used pipe insulation on mine. The 2" I believe that is already slit at Home Depot. I just slide the end of the window in it and it seemed to help. Not to mention it was a less then a dollar fix. I did it on the top around the doors too. I bought the stuff with the self adhesive for that area and then it lasted a winter or so.
Use the gray stuff and you hardly notice it, and they have a camper or window seal rubber trim that I did on the inside of the window frames that helped with the water issues too, especially melting snow.
Alex
Old December 12th, 2008, 06:35 PM
specops1526's Avatar
specops1526
Beluga '97 90
I've used the camper top foam weather stripping too. Works pretty good. You can probably put the sticky side down on the top of the rear door to block up that gap.
Originally Posted by rijosho
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old December 12th, 2008, 06:49 PM
Just FYI - the tailgate bar is supposed to have a piece of weatherstripping that slides into it. Its not secured, and easily slides out. When I ran my soft top (even crappy old bestop) this gap was never an issue and was adequately sealed with the piece of rubber.
90, 97, ac, d-90
Safari roof rack for 90 ST Cyborg Wanted 2 December 8th, 2009 08:56 PM
1994 Defender 90 ST $22,000 OBO sjmurphy For Sale - Vehicles 3 October 27th, 2009 08:52 PM
97 ST Alpine White Baja 90 For Sale - Vehicles 7 October 6th, 2009 01:20 AM
Rear Speaker housings - 97 ST bjf Wanted 11 November 7th, 2008 10:13 AM
Tuffy console '97 NAS 90 with Auto ronward Defender Technical Discussions 5 October 7th, 2003 09:39 PM
