Rails and Snaps.. Is this stock or modified? - Defender Source
Old June 19th, 2014, 03:36 PM
jijalicious
Jiman Khosravan
'94 D90
Afternoon...
I was thinking on the getting the tonneau that Ron was trying to sell... and seems my set up is not quite factory default... ST D90 '94.
Does this look like a modifed setup?
Should snaps have been all around? But instead the previous owner added the railing (side rear and rear) for the Soft top he put on?
~ji
Old June 19th, 2014, 03:55 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Yes, modified. For the 94' ST, those aftermarket rails were necessary to install Badger tops.
Old June 19th, 2014, 04:02 PM
Yes "aftermarket" but a very common "upgrade" since the snaps were only for 1994s and the belt rail (that black thing covering where your snaps were) system was used for 1995-1997, allowing more tops choices, including the Badger and RN tops. You can add the snaps on top of your belt rail though. Just source the snaps, figure out where they should go and drill, then install install. If you take the belt rail off while doing so, paint it to match your body color before re-installing.
Old June 19th, 2014, 04:15 PM
down_shift's Avatar
down_shift
Russell
Why would you ever want to do this? Once you go Badger, you don't go back.
Old June 19th, 2014, 04:37 PM
jijalicious
Jiman Khosravan
'94 D90
thanks for the info...
So then i'm looking for:
half tonneau
drop curtain top half
Bimini top
Bascailly My summer setup with the windows off...
Where would you go look for these goodies?
~Ji
Old June 19th, 2014, 05:59 PM
Originally Posted by jijalicious View Post
thanks for the info... So then i'm looking for: half tonneau drop curtain top half Bimini top Bascailly My summer setup with the windows off... Where would you go look for these goodies? ~Ji
For a non-gutter kit I presume (only applicable to the bikini in your scenario above).
mod
Modified Stock Tire Carrier 1 jerry can & highlift CDeWan For Sale - Parts 13 December 5th, 2012 09:35 PM
Modified Stock Carrier CDeWan For Sale - Parts 1 July 28th, 2012 03:15 PM
The two clips that the rear tailgate bar snaps onto and vertical rods for softtop evilfij Wanted 7 February 23rd, 2009 03:27 PM
Stock cubby box modified for sub TND90 For Sale - Parts 0 November 23rd, 2008 09:49 AM
Modified stock tire carrier :) TwisteD90 For Sale - Parts 10 December 12th, 2003 02:38 PM
