radius undone - Defender Source
Old December 4th, 2008, 03:03 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
radius undone
just in case anyone is running these silly perforated radius arms.....may be worth keeping an eye on them
Matt Browne
Old December 4th, 2008, 03:18 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Ouch, so much for reducing unsprung weight!
Old December 4th, 2008, 03:46 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
My D90 is lighter, but I will have to keep a watchfull eye. Which brand? Did it get hit hard?
Old December 4th, 2008, 04:34 PM
landrovered
S. Smith
I don't think you really need to hit anything, the front radius arms take a lot more abuse than we think they do.
Watch this video...
Old December 4th, 2008, 05:21 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Is that Jefro's rig?
Old December 4th, 2008, 05:24 PM
Grover's Avatar
Grover
How much weight are you actually saving with the holes?
Old December 4th, 2008, 06:56 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
yes thats Jeffro wrig.
I dont think he hit anything really, just normal (?) trail abuse.
Don't think they where installed to save weight,...needed castor correction. I generally use (or build) RTE style.
Matt Browne
Old December 4th, 2008, 07:01 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I bet that made hard braking interesting.
Old December 4th, 2008, 07:10 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
The only reason to drill those holes is to save weight and I bet it didn't save much. You can still get them with castor correction without the holes as this is done proximally near the bushing attachment point.
Most the the manufacturers that make the castor corrected arms are making them for "racing" so they seem to like to drill them for weight savings and possibly cosmesis.
They look cool but I was afraid that's what might happen.
This is a great post as it's something worth learning from although numbers of failures are probably pretty low.
junkyddog11
oil soaked filter
95 RRC 300tdi
'twas ok as the other side hadn't QuiTe broken yet.
Matt Browne
Old December 4th, 2008, 08:55 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
On my QT arms the holes are drilled along the radius arm and not around the axle. The same is true on my Equipe arms. That is why I was curious about the manufacturer. Is there rust/corrosion in the area? How malleable is the steel? Somehow this doesn't compute in my engineer's brain. Failure should have been at one of the attachment points unless there is a crack or something else in that area.
Old December 4th, 2008, 10:52 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
If you look carefully along the left hand side it looks like the outer strip of steel peeled off the core (part with holes in it) at the weld (looks like they are welded not likely carved out from a billet). After that it just tore like a piece of paper through the stress riser, ie the hole next door. Both the QT and Equipe have same designs. I have heard of weld imperfections and quality issues, ie consistency issues on some of the QT stuff.
Old December 5th, 2008, 07:24 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
There would be considerable stress in that area during extreme articulation (literaly trying to twist the axle) . There is no corrosion present. They were not damaged from impact. They were a little over a year old.
Matt Browne
Old December 5th, 2008, 10:58 AM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
I'm curious how much of a factor rust can be with regarding strength and durablility retention. I don't think surface rust would be much of an issue, but at what point would rust really start to become a factor? I saw this pic on a rig on ebay with Equipe lower control arms, with a "slight" amount of rust. It will only get worse without addressing the problem. Not sure if I would like to see that under my rig.
I'm still in my "research" phase regarding suspension for my D90 and Equipe and other Euro manufactured suspensions are possible options, but they seem a little steep in price for what you get. Someone tell me different Seeing that photo you posted makes me wonder if they are worth it. I'm not exactly sure if those arms are Equipe, Scorpion or some other manufacturer, but I might be heading in a different direction (when it comes to the "perforated" design).
Anyone out there knows who produces a setup that pays special attention to corrosion resistance? Living in the Northeast makes this a concern for me. Thanks!
Old December 5th, 2008, 11:05 AM
landrovered
S. Smith
Those have the equipe logo on them but for $1400 I would expect them not to rust like that. I thought they were anodized or something because they look so good when they are new. Thanks for the picture, I am now thinking differently about the equipe stuff.
Old December 5th, 2008, 03:53 PM
Cube II's Avatar
Cube II
Michele
1997 D90
Equipe makes the billet radius arms out of ergal (which I believe does not rust but I might be wrong here).
The Qt ones are made of steel strips welded together.
I have an old issue of LRM (or LRW) showing a pic of the parts I might scan for those interested...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old December 5th, 2008, 04:15 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Does not look like the parts were serviced correctly and failed to me! LOL
Bolts were overtorqued-installation problem! LOL
Why would anyone even run those holy parts. Cleansing of the gene pool, attracting vain LR owners?
legend in my own mind
Old December 8th, 2008, 07:49 PM
junkyddog11
oil soaked filter
95 RRC 300tdi
In fairness these arms were made by QT Services and aparently intended as "show" items for display only and were not intended for installation. I'm not sure how they ended up on the truck as we did not install them.
Dave Marsh of QT Services has been very helpfull in correcting this situation in a true "stand up guy" fashion.
Matt Browne
SG and Hinged and pinned castor corrected radius arm Shane@EVS For Sale - Parts 5 March 21st, 2006 11:20 AM
Used D90 Radius Arms Northface Wanted 3 March 29th, 2005 08:42 PM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
Radius and Trailing arms chrisvonc Defender Technical Discussions 18 June 9th, 2004 10:21 PM
WTB - Caster corrected radius arms Tawayama Wanted 4 February 12th, 2004 12:35 AM
