Radius Arms Narrow vs Wide - Defender Source
Old March 1st, 2016, 08:16 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
After going through a lot of hassle replacing the front brakes on my 110, I have determined that the truck is not sporting it's original front axle. Being an ex BATUS vehicle this isn't a big surprise.
Ready to buy a complete set of bushes and looking at the SuperPro kits from Paddocks. Problem is the kits are for narrow radius arms (early) and wide radius arms (later). Only item different between the two kits is the Front Radius Arm to Axle Bushes. What do I need to measure to determine which radius arms I have. The 110 is a '95 but the front axle seems to be much earlier.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old March 1st, 2016, 08:23 PM
Narrow:
* Outer diameter: 51.00mm
* Outer length: 38.00mm
* Inner diameter: 16.00mm
* Inner length: 47.00mm
Wide:
* Outer diameter: 50.50mm
* Outer length: 44.30mm
* Inner diameter: 16.20mm
* Inner length: 54.00mm
Old March 1st, 2016, 09:23 PM
moose's Avatar
moose
Brett
Thanks for the numbers John. Winter has finally arrived in TO so I guess I will be crawling around in the snow tomorrow trying to figure out what I've got.
Brett
Ex-Mod 110 Tdi
Old March 1st, 2016, 09:47 PM
Maybe all Defenders are the same, but RRC has a smaller bushing on the frame side of the radius arm.
Old March 1st, 2016, 10:11 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Funny, I'm in the process of swapping my front axle out for a wide style RRC axle so that I can run RTE cranked arms. If you were closer, I'd say we should just trade.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old March 4th, 2016, 10:29 PM
moose's Avatar
moose
Brett
Was warm and dry enough to crawl around under the 110 this afternoon. From the measurements I got it seems my axle was replaced at some point and it is indeed an earlier axle with the narrower radius arms. Now at least I know what bushes to order.
Brett
Ex-Mod 110 Tdi
WTB: Sankey cover (for narrow track) nathanwind Wanted 0 June 6th, 2012 09:13 PM
Wtb sankey narrow track trailer scrubs Wanted 2 February 1st, 2012 04:20 PM
Sankey Trailer - 3/4T Narrow - $1200 djrover For Sale - Vehicles 3 September 13th, 2011 01:00 PM
Polybush brand D110/90 (up to 1993) Narrow Radius Arms bushings JohnC For Sale - Parts 0 July 6th, 2011 08:27 AM
Tuffy narrow console part number? KevinNY Defender Technical Discussions 1 January 5th, 2008 06:04 AM
