Radius arms - Defender Source
Old July 25th, 2015, 11:10 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Radius arms
Doing mine tomorrow, what's everyone's opinions on the easiest way to do them? Only have done them on my d2 before, a bit easier. I'll also be changing shocks, springs, panhard, and track rod if it makes it easier without any of those.
Thanks!
Old July 25th, 2015, 11:32 PM
Unbolt the old ones and bolt in the new ones would be how I would start.
Old July 25th, 2015, 11:43 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
God damnit Jimmy.
Old July 26th, 2015, 12:53 AM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
To add to Jeff's comments. When doing the panhard at the same time I find a single ratchet strap helpful to help pull the vehicle towards the drivers side to align the panhard and help with aligning the bolt holes on the front of the radius arms.
Old July 26th, 2015, 08:40 AM
gotta remove the track rod
Old July 26th, 2015, 08:58 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Good call, that's pretty much what I was looking for.
I'm assuming I'll have to insert the chassis side first and then install the axle side like the trailing arms, is that correct?
Old July 26th, 2015, 09:26 AM
All good advice...the only thing I can add is to get one of the two bolts in the radius arm all the way in first. That way it's trivial to get the second bolt in via some wiggling with a jack.
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The track rod will need to be removed. Do one side at a time. Chassis end first. Stick a bolt through one of the axle mounts. Walk the wheel forward and back to line up the second axle mount.
Once you get thw radius arms done I'd support the truck under the frame, take the wheels off, and drop the axle down to install the new springs.
Old July 26th, 2015, 09:27 AM
Affirmative, always insert the chassis side first and attach the nut. Don't torque down the nut, just get it on enough to prevent the radius arm from falling out.
Watch your noggin
Old July 26th, 2015, 09:50 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I have a couple of old radius arm to axle bolts I've cut short, one longer than the other, and tapered the ends. If I have alignment issues I drive them in from the opposite side from where I'll be inserting the bolts in order to get the holes aligned. Works very well.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 26th, 2015, 10:43 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Thanks Briggs, too late for that .
I'll give you a shout if I run into a snag.
Old July 26th, 2015, 11:05 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Nah I shaved.
Old July 26th, 2015, 11:12 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I hope you are shooting a video.
-Jeff
Nah I shaved.
Bummer- that was the best tech video on the interweb...
Rent my
Old July 26th, 2015, 11:21 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
I'll make one about changing your air filter and installing diesel fuel next!
Old July 26th, 2015, 10:35 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Well it's done...they weren't awful. The front shocks were way worse, what a terrible design, glad I swapped to eyelets all the way around.
Got a ton done this weekend... Just need to install the front locker now
Old July 26th, 2015, 10:49 PM
Did you just ending up bribing Brandon to do it with a bunch of free Schlitzeses?
Old July 26th, 2015, 11:31 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Haha unfortunately he was occupied this weekend. I did everything myself with the exception of my girlfriend operating the lift to get the bumper on. And cleaning
Old July 27th, 2015, 01:17 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Looks bad ass! 255/85?
Old July 27th, 2015, 09:09 AM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Yessir
Old July 27th, 2015, 05:44 PM
I'm really glad you swapped everything over to that truck instead of keeping it stock.
Free radius arms and trailing arms pick up near philly evilfij For Sale - Parts 12 January 29th, 2015 06:55 AM
Offset Radius Arms and Rear Trailing Arms OBXrover Wanted 0 September 28th, 2013 01:36 PM
Bolt size for Radius Arms and Rear trailing arms Rugbier Defender Technical Discussions 5 May 29th, 2009 10:23 AM
Radius arms or trailing arms sflash868 Defender Technical Discussions 12 May 28th, 2006 05:40 PM
WTB - Caster corrected radius arms Tawayama Wanted 4 February 12th, 2004 12:35 AM
