Radius arm size question - Defender Source
Old September 1st, 2012, 11:18 AM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
When I was looking around at new radius arms I found there are two different sizes then today I was getting under my truck to steer messing around with bushings and saw the gaps between the tabs and radius arm (see pictures). Is this right or did they put the wrong arms on my truck when they " built" it?
ID:	56918   Click image for larger version
Old September 1st, 2012, 11:25 AM
The gaps are normal. There is a steel tube in the center of the bushing and as long as that is firmly squeezed between the ears it's fine.
As far as the width goes I think there are two sizes and the defender ones are the wider. I just measured and they are 1and 3/4" wide at the front
Originally Posted by pendy
I'm here for the D's
Old September 1st, 2012, 12:05 PM
Early ones are narrow and later ones are wide. Change was in 93 or 94 and was marque-wide.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old September 1st, 2012, 01:26 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Thanks for the info
Old September 3rd, 2012, 03:05 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
From the 300Tdi (about 1996?.... VIN # LA930456 onwards...see attachment) the arms went wide... well, certainly in Europe they did, whether the NAS had the wide arms anyway I don't know.
Also they have wider bushes....NTC6781 earlier "narrow" bushes were NTC7307
Radius arm and trailing arm nut size dave_lucas Defender Technical Discussions 3 February 25th, 2010 04:44 PM
Radius Arm Bushing Question Craig T Defender Technical Discussions 4 April 16th, 2009 09:02 PM
Slotted Radius Arm Bushings -- Opinions? LRNAD90 Defender Technical Discussions 7 June 19th, 2006 11:37 AM
SG and Hinged and pinned castor corrected radius arm Shane@EVS For Sale - Parts 5 March 21st, 2006 11:20 AM
For Sale: Mantec Steering Guard, NSO Rear Shock Mount, Hinged Radius Arm Doogs For Sale - Parts 8 January 26th, 2005 11:28 AM
