Radius arm bushes or new arms for lift - Defender Source
Old September 1st, 2014, 07:04 PM
Jwillia's Avatar
Jwillia
Justin
87 ROW build in progress
I have a nice set of stock arms ready for new bushings. Should I use the camber correcting bushings or get the Arms made for the two inch lift?
Old September 1st, 2014, 07:51 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
97 NAS Station Wagon LE
Don't need to correct caster when lifting 2". You need to at 3".
Old September 1st, 2014, 07:53 PM
Jwillia's Avatar
Jwillia
Justin
Really that's good to know. No need in using cranking bars in the rear either?
Old September 1st, 2014, 07:58 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
Those will give you more droop with longer shocks or lowered shock mounts but at 2" you can leave them stock.
Old September 1st, 2014, 08:11 PM
Jwillia's Avatar
Jwillia
Justin
Cool! Do you know if the stock bushings sold on eBay are any good. Most of the sellers have great reviews.
Old September 1st, 2014, 08:41 PM
Arcadeus's Avatar
Arcadeus
Mark Bichin
I know that Oem bushings are good and often the best option... I can't say anything about what is being sold on eBay...
Old September 3rd, 2014, 07:20 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
This really depends on the springs you use and how much lift you get. I have done 2" lifts that needed the caster correction since the steering was very sluggish returning to center. If that's the case do the arms. I have always used Rovertym with there arm modification.
Legend in My Own Mind.
Old September 3rd, 2014, 09:00 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Not necessarily. Cranked arms(front and rear) do more that correct castor, they alleviate bushing bind at the frame. Cranked arms are often much beefier than stock ones, especially the rear arms.
I have had really bad luck with supposedly OEM bushings. At this point the quality control really isn't there as far as I'm concerned. I would go with an actual Genuine bushing with the green/white label or a PolyBush in Red, Blue, or Orange.
Offset Radius Arms and Rear Trailing Arms OBXrover Wanted 0 September 28th, 2013 01:36 PM
New Rovertym Radius Arms for 5" Lift Wolf Fabrication For Sale - Parts 0 August 25th, 2010 04:49 PM
Radius arm and trailing arm nut size dave_lucas Defender Technical Discussions 3 February 25th, 2010 04:44 PM
Bolt size for Radius Arms and Rear trailing arms Rugbier Defender Technical Discussions 5 May 29th, 2009 10:23 AM
Radius arms or trailing arms sflash868 Defender Technical Discussions 12 May 28th, 2006 05:40 PM
