radio wiring help needed!! - Defender Source
Old August 3rd, 2014, 07:33 PM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
OK board, thought this was pretty straight forward but I guess not.
Factory radio/factory wiring harness etc.
gray plug on back of radio with 5 wires:
red/black
purple/gray
white/orange
black
yellow/purple
pink plug on back, 8 wires to speakers 2 each.
All of the wires matched up, annnddd....
Nada, no nothing from radio. the only really weird thing is that now my chime for seat belt and key left in ignition sounds like Elmer Fudd after doing Ether...a really slowwww drawn out chime, completely different from normal... any thoughts?
Thanks!
KCD
Attributed to Shayne...
Old August 3rd, 2014, 07:52 PM
the rover shop
shayne young
Radios nowadays need... Constant power...(usually yellow). Ignition switched power..(usually red) ground..(usually black) A remote on wire..(usually blue)..(supplies power out when radio is switched on..usually to turn on an amplifier.) and an illumination light signal (wanna say usually orange) (power when lights turned on..(or dims radio when lights turned on),..
I checked my factory light diagram and it doesn't match up with what you wrote..the two plugs sound like what is on a discovery 1 radio.. Will check tomorrow if you still need it..
Old August 3rd, 2014, 08:00 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Sounds like a short. Take the radio out, put it on your bench, and connect a power supply to it to test. If ok, then use the same harness to test it again. If ok, then go through the car connectors for the short.
Then test with no loads (no speakers connected at the harness)
Old August 3rd, 2014, 08:05 PM
kevincdoyle
Kevin C. Doyle
getting closer...
OK first of all something weird.
Checked fuses and the hazard fuse was glowing red, someone put a 20 amp in. Replaced it with a 15 amp and now everything sounds and looks normal. Radio comes on but won't accept code, any other thoughts?
Scouring the neighborhood for a Night Ranger cassette to see if it will take cassette....
Old August 3rd, 2014, 08:17 PM
rankar's Avatar
rankar
Try to unplug harness and hold the power button down for ten seconds. Reconnect harness, enter code, and crank sister Christian on full blast!
Old August 3rd, 2014, 08:33 PM
kevincdoyle
Kevin C. Doyle
dammit, no go.....
screen lights up and everything, just will not accept code, just the 4 lines across...
any other thoughts other than 4X4 radio?
trying to sing me away, nothin' happening....
Old August 3rd, 2014, 08:42 PM
rankar's Avatar
rankar
Yes make sure your battery is putting full voltage out. Radio won't accept code if is battery low.
Try turning the engine on, let it run for a minute, then try.
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
This is what I replaced mine with, it's actually made by Jensen.
http://www.ebay.com/itm/New-Ford-Tra...item4ac83ae196
http://www.aiproducts.com/techbullet...440ENGLISH.pdf
Old August 3rd, 2014, 09:13 PM
carlosz's Avatar
carlosz
Carlos
the 12volt.com...your radio wiring friend...
Old August 3rd, 2014, 09:50 PM
kevincdoyle
Kevin C. Doyle
tried that....
I'm about 99.9% sure it is wired correctly, radio lights come on, dim, etc when I put on headlights and parking lights.
Even got a little bit of noise from all four speakers when I plugged in pink speaker plug.
It's just not accepting any numbers when I push them to enter code.
Guess I'll have battery checked as a first line to shipping off.
Damn, hours on this and I thought I had it...
On a positive note, it looks effin awesome!!
I'll do a few more searches and see if I'm supposed to face East or West and say some sort of Lucas incantation...
Thanks for all the quick help guys!!
Old August 3rd, 2014, 09:53 PM
rankar's Avatar
rankar
Still try to pull it out and bench test. Gotta hear some night ranger over here
Old August 3rd, 2014, 10:12 PM
kevincdoyle
Kevin C. Doyle
Wooooo hoooooo!!!! Success!!!!!!!!!!!!!!!!!!!!!!!
Believe it not Board, SEARCH WORKS!!!!
I read through quite a few posts about codes and found a few about holding BND button down for 5 seconds..
Went back out there in the pitch dark to try it and SUCCESS!!!!
Sounds awesome! I'm overly excited according to my daughters..
(they wanted to know what a cassette was)
Night Ranger.....coming uppp!!
Thanks again so much guys!!
KCD
Old August 3rd, 2014, 10:29 PM
rankar's Avatar
rankar
Bitchin. Now crank it!
Old August 13th, 2014, 10:19 AM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
I can't get the code off my radio. Going to replace it for now. Does anyone know if the wiring harness for the 1997 disco will fit the D90 wiring? I would rather not cut original defender harness to put in aftermarket radio. Thanks
Old August 13th, 2014, 10:22 AM
the rover shop
shayne young
Buy the adaptor harness.. Read the first couple of responses in this thread..
Old August 13th, 2014, 10:30 AM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Rover shop. I am not seeing where to buy the adapter harness. Maybe I am missing something.
Old August 13th, 2014, 11:04 AM
rankar's Avatar
rankar
Check to see if Metra Harnesses has one
Old August 13th, 2014, 11:45 AM
the rover shop
shayne young
Type into eBay rover radio harness or adaptor and you can make sure they have the right plugs for your application by the pics.. Cheap as..... And fast shipping.. If not I'm sure I probably have some laying around if you are in a hurry... But hard to beat the speed of eBay... Even from china lately..
Old August 13th, 2014, 02:58 PM
nflory's Avatar
nflory
Nate
1997/Defender 90 ST
Thanks folks. I check metra and doesn't look like they have it. Anyone know if this was the same head unit/harness as any other rover that year? Thanks
Old August 13th, 2014, 03:03 PM
the rover shop
shayne young
I see you are from Idaho.. That reminds me of a joke .. Anybody know why there was only 51 contestants in the Miss Ebonics USA contest...???
radio, wiring
ignition wiring help needed.. kevincdoyle Defender Technical Discussions 2 January 19th, 2014 10:49 PM
ignition wiring help needed spartan Defender Technical Discussions 3 June 26th, 2013 02:13 PM
Speaker Wiring Help Needed NoVaKevin Defender Technical Discussions 10 February 14th, 2011 02:49 PM
radio wiring harness adapter for aftermarket radio mightymg Wanted 8 March 25th, 2010 02:56 PM
Radio install/wiring help needed. Firefighter2904 Defender Technical Discussions 5 August 8th, 2007 09:39 PM
