Radio Wires - Defender Source
Old October 11th, 2006, 04:42 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
Radio Wires
I'm putting a new head unit in my Defender, and have all the wires identified except a solid yellow wire, and a red wire with a black horizontal stripe on it about every 2 inches or so. Any one got any ideas? Thanks
Alright, the red and black is connected to the headlights, and the yellow one has a purple stripe that I didn't see before. I can't figure out what that one does, it was not hooked up to the previously working radio (which worked fine). In a previous post someone mentions that a yellow/purple wire in a 97 is switched power, but that does not appear to be the case hear (truck is a 95). Thanks for the help.
Old October 11th, 2006, 05:04 PM
gtg067i's Avatar
gtg067i
Christian Shea
1997 Defender 90 Wagon
I am about to replace mine, is there a place where each wire is identified so don't have to guess and check? Or if someone had a link or had a key to them it would be great if someone could post it or where to go.
I require your largest, cheapest, most alcoholic brewed beverage.
Old October 11th, 2006, 06:37 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Did you look in the FAQ of this site?
Old October 11th, 2006, 07:20 PM
gtg067i's Avatar
gtg067i
Christian Shea
Thanks for the point in the right direction, forgot to even consider the FAQ
Old October 11th, 2006, 07:45 PM
Raider's Avatar
Raider
Adam Knox
95 ST AA Yellow
I've checked the FAQ, but didn't see the yellow/purple wire identified.
Old October 11th, 2006, 09:02 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
All right, here is what I wrote down when I put in a new head unit:
power (switched):___White
ground: ___________Black
Continous 12V ______Red
Rear Left ________Black/White
________________Black/Brown
Rear Right _______Peach/Black
________________Red/Black
Front Left _______Orange/Black
________________Yellow/Black
Front Right_______Blue/Black
________________Green/Black
I don't thnk I hooked up the purple. I can check tommorow. Maybe I should have. Oh well, the radio works fine except for the crappy stock speakers I still have. Is there an amp under the passenger's seat? Maybe it has something to do with that.
Old October 11th, 2006, 11:09 PM
Just a guess, but alot of radio systems have a radio sourced switched power to activate a power antennae.
Old October 12th, 2006, 06:13 PM
gtg067i's Avatar
gtg067i
Christian Shea
OK this one isn't covered anywhere from what I can tell, but will my factory clarion changer work with my new Kenwood receiver? The cable fits the Kenwood fine and I have a matching Kenwood changer but would rather keep the clarion since it fits perfectly in the console. Anyone know?
Also, when I rewire the harness for the new head unit should I solder all the connections and heat shrink them, or more aptly is there anything in addition to doing that I should do?
Old October 15th, 2006, 07:13 PM
gtg067i's Avatar
gtg067i
Christian Shea
Okay, I am dropping the head unit in tomorrow or tuesday, can someone either confirm or deny whether a Kenwood will interface with the clarion changer since the plug fits both without issue?
Old October 15th, 2006, 08:56 PM
i think the clarion changer is C-bus. its got I think a 16 pin plug?? check crutchfield. I ordered a changer from them but thank god i was able to bring my stocker back to life. the stock system is nice but does leave a little more to be desired..
radio
Which Radio plugs work in 95 D90? Gkase Defender Technical Discussions 11 July 25th, 2011 12:41 PM
How do I get my radio to work???? Chris Cox Defender Technical Discussions 5 May 31st, 2008 09:49 PM
'97 Defender radio & changer setup? Defender50th Defender Technical Discussions 6 September 27th, 2005 11:22 PM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
97 radio plug arrangements Gkase Defender Technical Discussions 1 October 6th, 2003 06:58 PM
