Radio relocation on a 97ST - Defender Source
Old April 1st, 2009, 09:09 PM
JMPDIV82
Gregg O'Neill
97/D90
Guys
Has anyone successfully relocated the Radio from the center console to the dash using the LR stock dash mount? Please let me know if you have part lists, directions and pictures.
BTW My search of the D90 site resulted in several discussion on the topic but no real solutions.
Cheers
Gregg
Old April 1st, 2009, 09:21 PM
dbj836
Brad Jones
I just put in the Iron Goat center dash (http://www.defenderdash.com/). I also replaced the speakers and placed an amp in the center consule. I also adapted a SPOD aux management system into it to help with future lights, ARB's, etc ..
It was a little pain in the a.. to run all the wires but it was do able.
End result was worth it.
I will try to post some pics this weekend.
Old April 2nd, 2009, 10:00 AM
JMPDIV82
Gregg O'Neill
97/D90
[font='Verdana','sans-serif']I really want to keep the original look of the interior. All my Aux switches were going to be hidden under the radio cover on the center console. The radio was going to be the only thing that was going to be exposed up on the dash. [/font]
[font='Verdana','sans-serif']Can you tap into the power window wiring harness to power the Radio? If that is doable then all you would really need to do is re-route the antenna and figure out how to stuff the radio and vehicle control box (the box behind the dash mount blank) into the radio mount. Thoughts??[/font]
Old April 2nd, 2009, 10:04 AM
The fuse box is so close by that it makes little sense to tap into anything to power the radio. If it was me, I'd undo the radio wiring (I dont know if it goes under the body in the 97 or just down through the console) no matter how it was routed and use the same stuff to install the radio in the dash. To relocate the little control box, perhaps you can just make a new cover for the center dash switches that has more space in it?
97, radio
How do I get my radio to work???? Chris Cox Defender Technical Discussions 5 May 31st, 2008 09:49 PM
Brand new Radio Relocation Kit D 90 110 CDeWan For Sale - Parts 11 February 15th, 2008 04:19 PM
'97 Defender radio & changer setup? Defender50th Defender Technical Discussions 6 September 27th, 2005 11:22 PM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
97 radio plug arrangements Gkase Defender Technical Discussions 1 October 6th, 2003 06:58 PM
