Radio Interference With Headlamps On - Defender Source
Old January 25th, 2009, 05:29 PM
Haston
Christopher Petite
Trying to resurrect the interior of a 97 SW. I installed new Kappa speakers in the front doors (twice since I negelected to make sure the windows could roll down with the new speakers in place). Everything tested out fine except that when I turn the headlights on, I get a wicked buzzing noise over the audio. Any guesses on a good fix? H.
Old January 25th, 2009, 05:55 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Specifically with the radio? or also with CD playing?
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 25th, 2009, 07:43 PM
Haston
Christopher Petite
Buzzes on cd as well, but less pronounced-- but, again, only when the parking lamps and headlights are engaged. The original amp and cd changer are no longer with the truck.
Additional information that outlines the problem and my futility:
when the driver's side speakers are unhooked, the buzzing goes away.
Presumably, I have to start chasing ground wires.
If I were to use a filter or capicitor, where would I put it?
Old January 25th, 2009, 08:17 PM
huck1974's Avatar
huck1974
shane cates
94 d90
Grounded to the same location????????
And hay
And I love you too
Old January 25th, 2009, 08:40 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Did you run new speaker wires or did you reuse the original ones?
Old January 25th, 2009, 09:00 PM
Haston
Christopher Petite
I used the original wires. Previous owner had unhooked the driver's side wires. (Perhaps now I know why.)
Old January 27th, 2009, 08:49 PM
Haston
Christopher Petite
I managed to figure out that I had unwittingly crossed a pair of speaker wires. Incidentally, I was set on the right track by the common sense of those kind enough to respond to my plea, as well as the following link on supressing stereo noise/interference:
http://www.termpro.com/articles/noise.html
All best. H.
Old January 27th, 2009, 10:58 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Do D90's share the speaker grounds in OE setup? Are you still using the original amp?
Old January 28th, 2009, 09:47 AM
GYM's Avatar
GYM
Gary
97 SW
[QUOTE=Stmpede]Do D90's share the speaker grounds in OE setup? [QUOTE]
I've wondered about this same question as well.
Old January 28th, 2009, 11:09 AM
Haston
Christopher Petite
Nothing in my system is original, for better or worse. I've yet to trace all the loose wires in the harness, as it;s a spaghetti mess.
lamp, radio
Which Radio plugs work in 95 D90? Gkase Defender Technical Discussions 11 July 25th, 2011 12:41 PM
How do I get my radio to work???? Chris Cox Defender Technical Discussions 5 May 31st, 2008 09:49 PM
'97 Defender radio & changer setup? Defender50th Defender Technical Discussions 6 September 27th, 2005 11:22 PM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
