Radio install - Defender Source
Old August 7th, 2015, 06:31 PM
Defenderdude
Jason
1983 Defender 110
Radio install
I'm going to be installing a radio into my 83 110 which has never had a radio and was wondering if anyone knows what kind of harness I need for this job? If there is one how much of a task is installing a radio and speakers on a defender?
Old August 7th, 2015, 06:45 PM
A CB radio or SSB?
Old August 7th, 2015, 06:55 PM
I'm guessing he is talking about a stereo. If that is the case you will need to make one yourself off of the pigtail that comes with the radio. Pretty easy stuff for even a novice.
Old August 7th, 2015, 08:01 PM
BlackField's Avatar
BlackField
Oscar
D110
Depending how crazy you want to get with the install it can be as easy as:
- running a wire wrapped around a fuse (might not be as easy if you have glass fuses).
- tap into the Ign + bundle (white wire), and ground bundle (black).
- speakers are easy to wire, hard to mount.
- You can go all out and run wires from the battery with in line fuses also.
As long as you have a fuse in there I think you will be fine. Consider a marine radio!
Old August 7th, 2015, 09:05 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
I am going to put a CB radio in mine - it has a stereo which I plan to leave in. Will probably mount the CB in a to-be-purchased cubby box. Any idea how tough the installation would be?
Old August 7th, 2015, 10:17 PM
Defenderdude
Jason
1983 Defender 110
Ya sorry should of said stereo but ok so I'm just gonna have to splice some wires, or is there an aftermarket harness I could get
Old August 7th, 2015, 10:26 PM
No harness. You will need to "roll your own".
Old August 8th, 2015, 09:23 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Puff, puff, give. Remember kids, don't fuck up the rotation!
radio
radio wiring harness adapter for aftermarket radio mightymg Wanted 8 March 25th, 2010 02:56 PM
'97 D90 radio install help Defender50th Defender Technical Discussions 0 October 18th, 2005 03:19 PM
Dash install of radio paulb Defender Technical Discussions 3 December 17th, 2004 05:42 PM
satellite radio antenna install nykx Defender Technical Discussions 8 November 29th, 2004 10:49 PM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
» Defender Registry
95 RRC
WeBeCinYa
Landy
x-pat
Add your Defender
