Radio Antenna Help - Defender Source
Old January 17th, 2015, 05:45 PM
Kobzya
Anton
Radio Antenna Help
Hey guys,
The radio antenna on my '97 D90 is busted - I was wondering if you could recommend any antennas that give you good reception but don't stick out like 30 inches (unless those are the only ones that work well). Has anyone had any experience with the little shark fins, or are they absolute garbage?
Any help would be greatly appreciated!
Thanks a lot,
Kobzya
Old January 17th, 2015, 08:25 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
You'll have to do some adapting but it's a great antenna. Wire in an extra switch, and it'll retract for the brush, while still listening to your AUX input
http://www.ebay.com/itm/NEW-Hirschma...1eb04b&vxp=mtr
Old January 17th, 2015, 08:52 PM
The stock unit is cheap enough. I think RN has them.
Old January 18th, 2015, 08:09 AM
Kobzya
Anton
Thanks Rijosho, I think I may jut do that if there are no better alternatives.
Old January 18th, 2015, 08:56 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Idk if this is the case with the other NAS90's but my 97 antenna requires a dog leg fitting at the back of the unit. Make sure what you go with can accommodate this or you plan ahead for a workaround.
Clay
Old January 18th, 2015, 08:57 AM
lbowers
L Bowers
1997 D-90: ST, BRG
I've got one I took off my 97 if you are trying to keep it stock. I probably cut the wire a little too short, but if you think you can make it work, you can have it. Part of my New Years resolution to reduce my parts stockpile...
radio
Wanted OEM flush mount antenna...or cap for antenna hole mfj20th Wanted 2 April 14th, 2010 08:21 AM
1997 Radio Antenna Removal ronward Defender Technical Discussions 12 August 8th, 2007 08:21 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
94 Radio antenna part # flippedrover Defender Technical Discussions 5 August 23rd, 2004 08:49 AM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
