Radio Antenna - Defender Source
Old February 12th, 2007, 03:46 PM
outfield
Steve
1995 D-90 SW #351
Radio Antenna
I have the stock radio in my 95 D-90 and need to replace the antenna. I have searched some threads and guys say they replaced thiers with off the shelf units.
My problem is the off the shelf antennas have a differnt terminal on the COAX and won't fit into the back of the radio. Mine has a 90 degree terminal, and the center stud is smaller diameter and shorter then the antennas I have found for sale.
Any suggestions on where I can find a antenna that will fit?
Old February 12th, 2007, 05:21 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Atlantic British or Rovers North.
Jimmy Buffett
Old February 12th, 2007, 10:59 PM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
I got a Rover junkyard to pull one out of a disco I and clipped the wires that I needed.
Old February 13th, 2007, 08:13 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I think I saw some parts at Radio Shack that might work.
Old February 14th, 2007, 02:52 PM
outfield
Steve
1995 D-90 SW #351
Thanks for the suggestions.
I ended up going to a CB Radio shop and they cut the end of the original antena coax off and soldered it to the new antena coax.
radio
1997 Radio Antenna Removal ronward Defender Technical Discussions 12 August 8th, 2007 08:21 PM
Shark fin radio antenna paulb Defender Technical Discussions 10 February 21st, 2005 11:24 PM
satellite radio antenna install nykx Defender Technical Discussions 8 November 29th, 2004 10:49 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
XM Radio antenna install Location - Where? COSteve Defender Technical Discussions 37 July 11th, 2004 07:50 PM
