Radiator Replacement - Defender Source
Old September 16th, 2004, 11:20 AM
sonny reagan
Sonny Reagan
Anyone here replace their radiator (95 NAS 3.9L)? I have only 1 day to screw with it and I haven't decided whether or not to call the shop. Looks easy in the book...just wanted to hear from someone who has done the work. Thanks.
Old September 16th, 2004, 02:21 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I didn't replace mine, but I had to take it loose to do some other work. I'ts not hard to do at all - easily done in a day. The biggest problem was getting the clutch fan loose - mind the reverse thread & be aware that the whole assembly comes off of the hub from the water pump as one threaded-on unit and does *not* unbolt from multiple studs/nuts like most US models.
ac, radiator
