Radiator Oil Cooling Function - Defender Source
Old May 15th, 2010, 07:28 AM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
How much of the cooling of the engine is accomplished by the oil cooler? How is the oil cooler integrated into the radiator? Is oil cooled by the water that has been cooled by radiator (the oil lines are on the return side of the radiator), or does the oil cooler have its own horizontal air cooled tubes like the water/antifreeze mix?
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old May 15th, 2010, 07:59 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Fluid to Fluid with the oil cooler passing the hot oil through a tube inside the radiator. the engine typically runs around 195* and oil tends to get a little hotter than that, so there is some heat exchange. It must work as the Rover engineers deemed it necessary, but I wonder just how much long term effect it really has.
Maybe using fluid to fluid keeps the trans or engine oil temperature range under control. If it was air to fluid, on cold days the returning fluid would be much colder and on hot days the opposite.
I'm a mechanic, not an engineer, so these are just opinions!
Email is
Same place, new dogs.
Old May 16th, 2010, 11:45 AM
I asked the same question on another section of this forum and the consensus is that the oil cooler is not needed. The engine oil can't get hotter than the rest of the engine or else we have a huge problem with the laws of thermodynamics.
Old May 16th, 2010, 01:47 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
After replacing oil lines in a D-90 SW last year I ran the truck last May in the AZ heat. Checking the temperature difference between the cooler intake and exhaust, the difference was only about 10-15 degrees. Also, our 03 disco II does not have an engine oil cooler. Maybe you need the cooler if you are towing a lot of weight, up steep mountain roads, etc. Don't think it is required for round the town, or non-stressful driving.
radiator
Defender cooling fans with clutches pendy For Sale - Parts 2 January 15th, 2006 11:47 PM
Radiator Cooling Trouble mgrgpg Defender Technical Discussions 29 March 14th, 2005 05:43 PM
Electric Cooling Fan Brackets wea Wanted 0 December 8th, 2004 12:52 PM
cooling system rover4x4 Defender Technical Discussions 1 October 21st, 2004 02:02 PM
What cooling mods have you done? read Misc. Chit-Chat 6 October 24th, 2003 01:34 PM
