Radiator muff question - Defender Source
Old September 29th, 2013, 06:54 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
At what temp should one use a muff for a tdi?
Old September 29th, 2013, 07:01 PM
if your cooling system is working right, I would think it would need to be a blizzard out and subzero to need it. basically when your system can't keep the temps up.
the primary reason I have mine is for wading, mud and grass.
Mark Kellgren
KM4BOR
Old September 29th, 2013, 07:04 PM
It is never needed if everything is working properly.
Old September 29th, 2013, 07:14 PM
maybe in the arctic, but not CONUS.
Mark Kellgren
KM4BOR
Old September 29th, 2013, 07:31 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Great, thanks. Every once and a while someone mentions a radiator muff some was curious. I will be making frequent trips to Tahoe this winter and in the future but it usually doesn't get much below 0 there
Old September 29th, 2013, 07:38 PM
if you can't keep the temps up at 180-190F, your thermostat is shot.
Mark Kellgren
KM4BOR
Old September 29th, 2013, 08:19 PM
300tdi's can take a bit of warming up ... A muff can help you get the truck up to temp.
Old September 29th, 2013, 09:46 PM
I use a muff in the winter. I don't have problems with the engine keeping the temp up, but it warms up a lot more quickly with it on and the cooling system has no problem maintaining that temperature.
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
