Radiator Cooling Trouble - Page 2 - Defender Source
Old May 12th, 2004, 09:31 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
I think he is set on that company since they told him they did a lot of LR's and they all worked out. However, while I'm lifting his truck this weekend I'll talk to him and try to convince him to get more estimates or I'll take it and shop around.
Thanks Dave
World traveler
Old May 12th, 2004, 10:03 PM
souza's Avatar
souza
Dave Souza
1995 Defender 90 SW #275
I guess I can't speak for the results yet, as I don't have it, but it's a reputable local radiator shop that's been around for years. I know they've never done one for a Land Rover before, but there isn't really anything special about our radiators. They measure the core and order it up by size, then solder it back to the tanks!
good luck!
Originally Posted by Mike Hippert
I could run circles around Dave Souzas 90
Old May 12th, 2004, 11:13 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I am going to be in the market for a radiator soon. As I was shopping around I came across this company. Looks interesting. Marketed for Jeeps but may work well on Rovers.
www.novak-adapt.com
Old July 2nd, 2004, 11:36 PM
scot's Avatar
scot
Scot Yount
95 Coniston Green D-90 SW
Radiator
Help!! I have a '94 D-90 that starts overheating with temps outside as low as 80. Lots of rocks and debris have destroyed the cooling efficiency of the stock radiator and I need another. Does anyone have a source other than stock one as they inexplicably cost around 500 bucks!!
scot
Wherever I go...there I am.
Old July 2nd, 2004, 11:51 PM
Hey news man
Have a local radiator shop rebuild the one you have. They just pull the sides (tanks or caps or something) off and put new fins in.
Some more info here
http://www.defendersource.com/mod/cool.html
Old July 2nd, 2004, 11:52 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
There is a large list of things to check for Defender cooling issues, some that dont require you to replace the radiator but even if you do, you can have the radiator "recored" to 4 rather than the stock 3 cores which improved the cooling and you should not need to pay more than $400 for that. Also check to make sure your fan is working properly. Yet another thing to look for is to make sure there is not a air bubble in the system. Also check the thermostat. There are a few threads already dealing with overheating and I will merge this with them.
Chris von C
[/size]
Old July 3rd, 2004, 06:13 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I have a couple used ones if you want to go low buck. They are left over from repowers.
But I agree that a recore is the best bet. Have them install dimpled rows which help cool better.
JP
legend in my own mind
Old July 6th, 2004, 09:22 AM
Eric_S
Eric
'97 D-90 ST #1507
Scot,
I see you're in the Boston area. I had my radiator replaced in January with a re-cored radiator at City Side Garage ( www.citysidegarage.com ) in Ashland, right next to Framingham. Great bunch of guys and great shop.
Eric
Old July 6th, 2004, 09:38 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I can second that. Have Alan take a look at it. He's the man.
Old March 14th, 2005, 05:43 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Does anyone know the exact size of the stock radiator so I can have one made?
TIA
radiator
Torque Converter re-Install trouble Michael Defender Technical Discussions 3 November 6th, 2005 09:18 PM
I'm in trouble w/ the Mrs.. pix of Full Rack install needed paulb Defender Technical Discussions 5 June 6th, 2005 09:40 PM
Trouble with getting profile info chrisvonc Support & Suggestions 2 February 4th, 2005 07:55 PM
Trouble Starting in the Rain Matt Klapmust Defender Technical Discussions 5 January 19th, 2004 04:53 PM
