Radiator Cooling Fan - Defender Source
Old August 29th, 2008, 11:56 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I'm not sure what its actually called but the fan in front of the radiator which switches on at a certain engine temperature on my truck is not coming on. Is there a fuse for it? What makes it switch on? I can't figure it out, can anyone help?
Old August 29th, 2008, 12:10 PM
That one comes on with the AC, turn your AC on and it should start up. And it also comes on at when the temp rises above the factory setting.
Old August 29th, 2008, 10:52 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Does it not help cool the engine after certain temp is reached? I think you are saying that it does but it comes wit the AC. If so can i wire it to come on somehow even if I don't have AC. I'd like to keep it functioning but I am not sure how to do it. Any ideas?
Old August 30th, 2008, 09:07 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
It should kick on when the truck starts to get really hot. On my AC if I turn the temp to full warm the fan kicks on but the compressor doesn't.
Jimmy Buffett
Old August 30th, 2008, 09:10 AM
On my truck when I turn on the fan for the AC those fans on the condensor also turn on. I am not sure if this is how it is supposed to work, but its how my has always worked. The compressor turns on when I turn the thermostat on the AC in cab. They also help a little when your fan clutch isnt working correctly.
Old August 30th, 2008, 09:19 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Well I pulled the interior AC stuff and converted my compressor into an on-board air system. So when I turn on the compressor I am missing something with the fan. I need to wire the fan back to the thermastat.
Old August 30th, 2008, 10:15 AM
You could probably wire it to a thermostat or to a switch that you control.
Old August 30th, 2008, 08:08 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Well thanks to you guys I did just this. I wired it to a switch in the truck that I control at will. I also pulled my AC radiator out which ought to give me some additional cooling space.
I started out an amateur at cars and trucks. I didn't know how to wheel them much less work on them and now b/c of this site I am getting to the amateur plus status. If this were a mtnbike race I'd be racing sport class now instead of beginner. It sure is fun picking a project and completing it without any big SNAFU's.
Thanks Everyone.
Old January 15th, 2009, 11:43 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Mike, how long does it take you to fill a 33 inch tire from say 15 to 40 psi?
Old January 15th, 2009, 12:06 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I can fill a 35" tire in less than a minute so I'd say about 40-60 sec for a 33"er.
Old January 16th, 2009, 10:02 AM
1of40's Avatar
1of40
1of40
impressive. i sent you an email with a follow up question or two. hope you don't mind.
Clay
fan, radiator
Removing the fan & Fan clutch assy/ water pump arbik Defender Technical Discussions 20 February 2nd, 2011 09:10 PM
RUDD 4x4 GRIP Chains & Kenlowe Fan kit for Sale Barnett Childress For Sale - Parts 0 May 18th, 2005 07:24 PM
Fan replacement davedeojay Defender Technical Discussions 10 March 23rd, 2005 02:00 PM
Clutch Fan with fan 95 D90 3.9L Vadim For Sale - Parts 2 October 16th, 2004 06:19 AM
D90 -- Fan clutch and fan Vadim Wanted 3 August 1st, 2004 01:00 PM
