Radiator Coolant - Defender Source
Old July 2nd, 2012, 05:34 PM
Tkleis
Tim Kleiser
97 Defender 90
Radiator Coolant
Just wanted to know what people think is a good radiator coolant for a 97 D-90?? I'm in the process of changing my radiator and wanted to put a good coolant brand in the system. Thanks for any input.
Old July 2nd, 2012, 07:46 PM
Regular 'ol green stuff available anywhere. Nothing special about the 4.0 - just make sure you cut it with distilled water (not tap) or buy the pre-diluted.
Old July 2nd, 2012, 11:47 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Normal coolant as suggested and change it more often. I used PG for a few years but saw it go brown, so back to using EG.
Old July 3rd, 2012, 05:09 AM
If you are changing the radiator, now is the best time to replace the hoses!
Old July 3rd, 2012, 09:38 AM
Tkleis
Tim Kleiser
97 Defender 90
Thanks for all the information and help.
Old July 3rd, 2012, 03:40 PM
USLandy's Avatar
USLandy
Andrew
defender 90
distilled water is not the best to you because of the lack of impurities in the water it will actually corrode the radiator much faster, now that said dont use tap lol
Old July 3rd, 2012, 04:11 PM
Urine?
Old July 3rd, 2012, 04:21 PM
Naplm00
Matthew
I use standard green and add Water wetter
Old July 3rd, 2012, 06:21 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
do you cut it for a diesel motor also, How much?
Old July 3rd, 2012, 06:34 PM
Dex-cool at a 50-50 mix. None finer.
Old July 3rd, 2012, 09:23 PM
Distiller water is the right choice when mixing with coolant. The coolant adds all that is needed
Old July 3rd, 2012, 10:15 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
is Dex cool something you can get at the local auto parts place or is it some special stuff they have to milk from a lactating phoenix?
Old July 3rd, 2012, 11:48 PM
interesting as that is counter to what I have been taught and what everyone else is saying. So, what do you suggest using? LOL
Old July 4th, 2012, 09:02 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I guess it depends upon where you get the tap water from? A well, City water... My well doesn't have any chemicals in it but does have more metals than city water. In the city water they add chlorine, among other stuff, to treat the water. I have always used Distilled water as an additive to cut the antifreeze with no negative results.
This from "PEAK" antifreeze site when asked the question on what water to add
"Yes, tap water is commonly used for mixing with antifreeze, however, deionized water or distilled water is preferred. Do not use water softened with salts to mix with antifreeze."
Land Rover 110
coolant, radiator
