Radiator - Defender Source
Old February 1st, 2015, 11:31 PM
Nwkaustin
Neal Kaye
1989 Defender 110
Radiator
Hey Guys- does anyone know of an easy to install radiator for a 1989 defender 110 2.5 TD?
Old February 1st, 2015, 11:41 PM
easy to install ? Stock oe is dirt simple
Old February 1st, 2015, 11:44 PM
There is no such thing as a hard to install defender 110 2.5 TD radiator. Pull the jubilee clamps off and disconnect the hoses, disconnect the oil cooler lines if present and pull a couple of bolts off the top with a 13mm socket. Swap it out, put everything back, fill and you are done.
Old February 1st, 2015, 11:49 PM
Nwkaustin
Neal Kaye
1989 Defender 110
Where is the best place in the US to get one? Should I get the same radiator or upgrade to a new one?
Old February 1st, 2015, 11:50 PM
Rovahfarm
Safari HP
Rovers North
Atlantic British
There is no real upgraded radiator. You may also be able to get your current radiator rebuilt, especially if it is an all metal (no plastic) unit.
Old February 2nd, 2015, 09:55 AM
michael67's Avatar
michael67
Michael White
110 Tdi
I noticed you're in Austin. You may want to give Mr. Cool Radiator off of North Lamar a call. My 300 Tdi wouldn't cool down very well here in the Texas summer heat; the electric fans would run almost constantly, especially if I turned on the AC, was pulling a trailer, or climbing that hill on 2222 just east of 620. Mr. Cool Radiator made me a custom radiator that cools much better than factory - the fans rarely kick on in the summer unless I'm stationary in traffic or climbing a hill with a trailer.
The price was pretty reasonable and comparable to buying new. My only (minor) complaint is that the radiator is a tighter fit than the OEM. Pulling the intercooler out is a bit more of a pain, and the brackets that hold the radiator in place don't fit quite as nicely, although the issue is more cosmetic than functional.
Let me know if you want pictures - I'm replacing my water pump and the back side of the radiator is currently exposed.
Old February 2nd, 2015, 09:58 AM
Betcha can also have yours rebuilt by a local shop.
Old February 2nd, 2015, 10:05 AM
Sounds like a 19J motor so no intercooler.
radiator
Radiator Cooling Trouble mgrgpg Defender Technical Discussions 29 March 14th, 2005 05:43 PM
Radiator flippedrover Wanted 7 April 26th, 2004 09:50 AM
Radiator reservior overflow Neo Defender Technical Discussions 1 February 27th, 2004 11:51 PM
radiator cap 97 jorge Defender Technical Discussions 2 November 7th, 2003 09:12 AM
Radiator muff PT94D90 Defender Technical Discussions 4 October 24th, 2003 10:54 AM
