R380 Transmission mounts - Defender Source
Old June 17th, 2011, 01:05 PM
trybul
Craig Hobbs
D90 83
Hey,
So the deeper in get into this, the more i realize that i was very ill prepared for this project.
I am now at the stage where i have bolted the Transfer case to the Transmission... and just waiting for the cross member to come back from Galvanizing. Once it is here, I can put it in, and install my new shinny prop shafts :D
But i have figured that i should probably ask people way smarter then me in these regards. The old transmission that came out of the truck is an lt77 mated to the 2.5 na. The new Transmission is an R380 mated to a new 300tdi. I am doing this to factory. The R380 did not come with "rubber mounts" on it. Niether did the transfer case. I am wondering if i can use he ones off the old transfercase and lt77? or do i need to order different ones?
Thanks alot guys!
craig
Old June 18th, 2011, 10:48 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
For what you're putting in to it, I'd use new rubber isolators.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old June 19th, 2011, 06:24 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
ANR3200 / 3201. Prob $25/ pair. They are handed.
Matt Browne
mount, r380, transmission
1994 Transmission mounts? tomaco1 Defender Technical Discussions 2 December 12th, 2010 10:47 AM
R380 5-Speed Transmission w/ Bellhousing Chris Vitale For Sale - Parts 10 May 13th, 2010 08:37 PM
R380 Transmission mounts Shearpin Defender Technical Discussions 2 July 25th, 2008 10:06 AM
R380 Transmission Input Shaft Bearing Question Heath Defender Technical Discussions 0 March 15th, 2007 03:09 PM
3.9 engine, R380 transmission Shane@EVS For Sale - Parts 7 August 3rd, 2006 04:04 PM
