R380 Transmission mounts - Defender Source
Old July 23rd, 2008, 03:30 PM
Shearpin
Henry Stinson
'73 Series III SWB '84 110 tdi
Any hints or suggestions for changing 300tdi R380 tranny/t-case mounts with the transmission in situ? Will a jack and a block of wood provide enough clearance to remove and replace? Any wires, breathers, linkage clearances I need to be concerned about?
Henry
www.4x4freedom.com
Old July 23rd, 2008, 07:40 PM
moose's Avatar
moose
Brett
Ex-Mod Tdi 110 Hard Top
Henry
We installed my R380 with a floor jack, so changing the mounts is doable. I'm not sure though that there is enough clearance between the top of the gearbox and the seatbox/tranny tunnel to lift the studs on the mounts clear. Worst case, you have to unbolt the chassis mounts. Three long bolts on each side if I remember correctly.
Brett
Ex-Mod 110 Tdi
Series 3 88 Diesel Soft Top
Old July 25th, 2008, 10:06 AM
Shearpin
Henry Stinson
Brett
Hey, thanks or the reply. The rain quit long enough last night to spend some time under the 110 and check out the brackets you mentioned. I hope to get the parts today and get them changed out over the weekend....
Thanks again,
Henry
www.4x4freedom.com
mount, r380, transmission
R380 transmission wanted ember Wanted 2 June 17th, 2009 05:05 PM
R380 Transmission install in NAS 110 NashvilleRover Defender Technical Discussions 1 August 7th, 2008 03:45 PM
R380 Transmission Input Shaft Bearing Question Heath Defender Technical Discussions 0 March 15th, 2007 03:09 PM
3.9 engine, R380 transmission Shane@EVS For Sale - Parts 7 August 3rd, 2006 04:04 PM
How to identify an R380 transmission? cellulararrest Defender Technical Discussions 12 July 26th, 2006 12:02 PM
