R380 spline wear? - Defender Source
Old September 17th, 2013, 08:05 PM
galen216's Avatar
galen216
Galen Lentz
'98 D1
R380 spline wear?
When people talk about output shaft spline wear is this what they are referring to? One pic is the used transmission I just received, the other is a core unit I was going to rebuild.
'98 D1
Old September 17th, 2013, 08:36 PM
Yup that's it.
Whats wrong with the current transmission?
Old September 17th, 2013, 08:44 PM
galen216's Avatar
galen216
Galen Lentz
'98 D1
Originally Posted by rover4x4 View Post
Yup that's it.
Current transmission has a bad bearing going. It sounds terrible on cold mornings. The one with the wear was a used unit I bought and received today. I've always heard of the wear, but have never seen it myself. Wanted to confirm that I was correct before going back to the seller.
'98 D1
Old September 17th, 2013, 08:53 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
It's hard to tell from the pictures, but if that is the rearmost portion of the main shaft that protrudes into the LT230 T-case that the final drive gear slides onto, yes.
This is more commonly seen when the final drive gear is not cross drilled to allow proper lube to the splines and they run "dry".
Using the later cross drilled gear is suppose to eliminate or greatly reduce this problem.
I have also taken perfectly good early style (non-drilled) gears to the machine shop and had them cross drilled like their later cousins.
RDavisinVA
Old September 17th, 2013, 09:59 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
That top pic is the used one you waited weeks to get? Did they tell you it was worn out and not really usable before shipping to you?
Robert hit the nail on the head about the gear in the transfer case.
Man, I sure hope the seller does right by you.......
Email is
Same place, new dogs.
Old September 18th, 2013, 06:01 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Wow. I hope you got it really cheap. Cheap enough to make it cost effective to install a new shaft.
This is the spline wear on my '95 Disco at 265,000 miles and I wouldn't sell it to someone, at least not without a photo of it.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old September 18th, 2013, 07:59 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
It wasn't cheap, but the seller is making it right. It's a shame because I have a good mainshaft from a transmission I broke down to rebuild and it has a good mainshaft. Mine looks just like your picture and it was claimed to a 80k unit.
'98 D1
Old September 18th, 2013, 08:27 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
IMine looks just like your picture and it was claimed to a 80k unit.
Depending on how it was used, that main shaft could have easily had 80K on it especially with a lot of around town driving and if the oil level was low in the T-case, well you know the rest of the scenario...
See twins of these worn out shaft pictures all too often... helps keep our friends at Ashcroft deep into a going concern with no shortage of customers.
RDavisinVA
Old September 18th, 2013, 09:23 AM
I can only imagine seeing wear like that on some very soft alloy steel.
Old September 18th, 2013, 09:37 AM
atlcruiser
david
many
Seems the seller let some guys ship out a worn tranny from his shop.... not the good one he had pulled.
That fat bastard should be shot.
There will soon be a free rebuildable r380 core in central PA.
Terrence Anderson
Shipping Manager
URBAN LAND CRUISERS LLC
+44 404 915 1281
Atlanta, GA USA
URBAN LAND CRUISERS + ROVERS LTD
1st Floor, 2, Woodberry Grove
London
N12 0DR
UNITED KINGDOM
+44 020 8133 1557
Company Registration No. 09003009
Our new Vehicle Sales site:
Old September 18th, 2013, 10:14 AM
while flying monkeys can seem to be a convenient solution, they have consequences.
Mark Kellgren
KM4BOR
Old September 18th, 2013, 11:00 AM
ezzzzzzz
Mark Garrenton
I had a knowledgable person, no name to be mentioned, buy a 'good' 'Defender' R380 for me while in the UK a few years back. That box was one of two purchased under the same request. What I received was a worn out Discovery R380 with the infamous spline wear shown above. I had to order all of the rebuild parts from Ashcroft including a new mainshaft and drilled LT230 input gear. I also ordered all the bits to convert this to a Defender setup. Before I rebuild this box I am considering cyro treatment of the mainshaft (possibly gears too) and LT230 input gear to reduce or eliminate this potential problem.
Old September 18th, 2013, 11:08 AM
Cryo unfortunately will not help. The metal used is the problem. A custom made shaft out of a much stronger alloy steel with heat treatment would solve the issue.
Old September 18th, 2013, 11:20 AM
ezzzzzzz
Mark Garrenton
"Anything worth doing is worth overdoing" - Doc (RIP)
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
howling trans or Transfer case? Gkase Defender Technical Discussions 18 February 8th, 2008 11:08 AM
10 spline Series 2/2a/3 axles (3 sets) Seriesman For Sale - Parts 0 October 25th, 2004 12:53 AM
TruTrac, 24 Spline Shafts, CVs mudrover For Sale - Parts 6 June 15th, 2004 05:29 PM
