r380 shifting trouble - Defender Source
Old December 17th, 2015, 05:34 PM
I had trouble this this morning getting it into 3rd gear on way home now and all the gears work but in first and second nothing is keeping shifter in it H slot. I have massive side to side play of the shifter in every gear. Any theory?
Mark Kellgren
KM4BOR
Old December 17th, 2015, 05:57 PM
Broken lockout spring on shifter? Broken shifter?
Hopefully it is not internal to the transmission. I would pull the shifter assembly and see what is going on.
Old December 17th, 2015, 06:00 PM
grub screw?
Old December 17th, 2015, 06:24 PM
whatever it is, while in traffic, something happened and I have my H pattern back, but fwd of where it was before. something must be broken or loose in the shift assembly
Mark Kellgren
KM4BOR
Old December 17th, 2015, 06:45 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
It's a grub screw on the inside of the box. Remove the top inspection plate and you will see a mechanism that transfers the shift from upper shift rod to lower shift rod. The grub screw in that mechanism has come loose or broken.
Old December 17th, 2015, 07:25 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
X's 2!!!! You will slowly start loosing all your gears.
Old December 17th, 2015, 08:03 PM
ok, pulled gear lever housing and nothing was broken. I must not have fully seated the grub screw in the hole when i did my transmission a while back. it's TOWT now! Thanks everyone.
i still have all the rubbers off for test drive to work tomorrow, but I think I'm set.
I'll be ordering a grub screw as a spare! talk about a small part that can leave me stranded!
Mark Kellgren
KM4BOR
Old December 17th, 2015, 08:09 PM
Whew!
Old December 17th, 2015, 08:12 PM
Whats cool is Abe gave tech advice.....
Old December 17th, 2015, 08:18 PM
One of those r380? It's just playing with you
Old December 17th, 2015, 08:26 PM
solarguy's Avatar
solarguy
Abraham Bell
Man I do when I think I know what I am talking about.
Old December 17th, 2015, 08:35 PM
This is EXACTLY what my pattern was driving home tonight in rush hour walking speed traffic!
Mark Kellgren
KM4BOR
Old December 17th, 2015, 08:37 PM
solarguy's Avatar
solarguy
Abraham Bell
Old December 17th, 2015, 11:05 PM
the rover shop
shayne young
Or when you've had a couple of doobies...lol..
LT77 shifting vs R380 WeBeCinYa Defender Technical Discussions 10 January 26th, 2013 09:14 AM
Problems shifting out of 1st when cold chalkcreek Defender Technical Discussions 2 July 14th, 2006 10:56 PM
94 shifting problems jstrong98 Defender Technical Discussions 6 January 26th, 2006 03:06 PM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
Shuddering when shifting... mlw911 Defender Technical Discussions 1 August 26th, 2004 09:18 AM
